JLS
G2 patch files: 274
Posted: Sat Oct 14, 2006 3:48 am Post subject:
Help me - midi out |
Hi all
please help me
my G2 not transmit AfterTouch and PitchWheel to Midi Out !!!!
arpegiator, note, velocity and controller working fine
very thanks
sorry my bad english ( please patch example ) |
Joined: Apr 03, 2004 Posts: 19599 Location: The Netherlands, Enschede
Audio files: 116
G2 patch files: 317
Posted: Sat Oct 14, 2006 6:03 am Post subject:
Just a guess can't really find it in the manual, but maybe in "synth settings" sending controllers is off ? Well its the closest thing I could find. _________________ Jan |
JLS
G2 patch files: 274
Posted: Sat Oct 14, 2006 9:55 am Post subject:
This function not implemented in OS
Transmit only controllers, note, velocity, arpegio, midi clock
After touch and pitch wheel not controllers, this is extended midi parameter
New typ for Clavia developer OS 1.5
- update this very big bug  |
Joined: Jan 31, 2003 Posts: 17337 Location: Allentown, PA
Audio files: 107
Posted: Sat Oct 14, 2006 10:02 am Post subject:
Moving this to the bug list. _________________ --Howard
my music and other stuff |
davep
Joined: Jul 05, 2004 Posts: 465 Location: Oakland, CA
Audio files: 10
G2 patch files: 73
Posted: Thu Oct 19, 2006 3:46 pm Post subject:
My G2 transmits the pitch stick data OK, no problem here.
Regarding the aftertouch, I use it in an unusual way, but this may help you too:
I like to add some slewing to the aftertouch response so it has a longer decay after you release the note. This is more musical on patches that have a long release, so the aftertouch doesn't suddenly shut off while the note is still decaying. To do this, I use the "DEVICE" module in a patch to access the aftertouch signal, and then patch this signal through an envelope follower. I then patch the EnvFol output to a Midi Send module and assign the processed aftertouch signal to a cc#.
If you can't get the aftertouch to work in the normal way, you could use this method of using the DEVICE module and re-assigning the aftertouch signal to a cc# and set the receiving device to use this same cc#. _________________ Dave Peck |
JLS
G2 patch files: 274
Posted: Fri Oct 20, 2006 5:33 am Post subject:
im not use G2 but G2 engine
master key Kawai K1-II
Kawai ---- PC working PitchBend and AT OK
Kawai ---- G2engine -----PC not transmited
if use G2engine like midi processor
( other controllers working OK ) |
davep
Audio files: 10
G2 patch files: 73
Posted: Fri Oct 20, 2006 12:22 pm Post subject:
| megerov wrote: | im not use G2 but G2 engine
So you mean Pitchbend and AT from the Kawai is going into the Engine, but is not coming back out? Maybe I do not understand, but it sounds like maybe you should be using the midi THRU connector on the Engine, not the midi OUT connector? _________________ Dave Peck |
JLS
G2 patch files: 274
Posted: Fri Oct 20, 2006 12:58 pm Post subject:
im using midiout connector not miditrue
miditrue only send direct event from master key ( midi in )
if connect miditrue data transmited ok but not G2 midi processed
if connect midiout data transmited ok but not transmited Pitch Bend and AT |
davep
Audio files: 10
G2 patch files: 73
Posted: Fri Oct 20, 2006 1:57 pm Post subject:
| megerov wrote: | im using midiout connector not miditrue
Ah, I understand. That IS a problem. And the idea of the midi modules could not be used because those will only access the pitch bend & AT data that is generated inside the G2, not from something connected to the midi in, and the Engine does not generate these signals.
If this really is a bug and the G2 is losing the data that is coming in, then maybe there is a way to use a simple midi merge box to combine the pitchbend & AT from the Kawai with the final processed midi from the G2? I know it is clumsy, but maybe it would work. Wow, that is a major bug. _________________ Dave Peck |
Audio files: 116
G2 patch files: 317
Posted: Fri Oct 20, 2006 2:18 pm Post subject:
| davep wrote: | | maybe there is a way to use a simple midi merge box to combine the pitchbend & AT from the Kawai with the final processed midi from the G2? |
Not so simple I guess, at least in general, unless the merger could be made to filter certain data.
It really makes the G2 less useful as a MIDI processor. _________________ Jan |
JLS
G2 patch files: 274
Posted: Fri Oct 20, 2006 2:29 pm Post subject:
im use my creamware card like merge box and filter some midi event ( creamware midi merge module and midi filter )
Idea for new G2 module
midi merger module
midi filter module
sysex register in/out module
what new info about new G2 OS ? |
Audio files: 116
G2 patch files: 317
Posted: Fri Oct 20, 2006 3:35 pm Post subject:
| megerov wrote: | | what new info about new G2 OS ? |
Nothing I'm affraid ... _________________ Jan |
