Whitney Music Box
Page 1 of 1 [5 Posts]
jbum
PostPosted: Tue Oct 31, 2006 2:57 pm    Post subject: Whitney Music Box
Subject description: Some sample ChucK source code for producing this piece.
Hi Folks,
Thought you might like some sample ChucK code for playing with the Whitney Music Box algorithm. Here it is.
http://www.coverpop.com/whitney/whitney.ck.html
For a visualization of what is going on, check this link:
Code:
// Whitney Music Box
// Jim Bumgardner jbum@jbum.com
48 => int nbrDots;
55 => float baseFreq;
180 => float durationOfPiece;
2.0/nbrDots => float dotGain;
fun void whitneyDot(float baseFreq, float secs, int nDots)
   StifKarp voc => dac;
   dotGain => voc.gain;
   for (0 => int i; i < nDots; ++i)
     baseFreq => voc.freq;
     1 => voc.noteOn;
     secs::second => now;
     1 => voc.noteOff;
// Sample Chromatic Pitch Function
fun float pitchFuncC(float baseFreq, int noteIdx)
  return baseFreq*Math.pow(2,noteIdx/12.0);
// Sample Reversed Harmonics Pitch Function
fun float pitchFuncH(float baseFreq, int noteIdx)
  return baseFreq*(nbrDots-noteIdx);
for (0 => int i; i < nbrDots; ++i)
  spork ~ whitneyDot(pitchFuncC(baseFreq,i), durationOfPiece/(i+1), i+1);
durationOfPiece::second => now;
<a href="http://www.krazydad.com/">krazydad.com</a>
<a href="http://www.coverpop.com/">coverpop.com</a>
jbum
PostPosted: Wed Nov 01, 2006 4:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here's an alternate version which uses a SinOsc with a pluck-like envelope, and which uses more dots and harmonic pitches.
Note: I'm wishing there was a built-in ugen in ChucK for producing non-linear envelopes ala the CSound linen function - it would greatly simplify or eliminate the playNote() function in this code.
This version is nearly fast enough for real-time on my computer (unlike the last version).
Code:
// Whitney Music Box - sine waves with pluckish envelope
120 => int nbrDots;
20 => float baseFreq;
fun void playNote(float freq, float amp)
    SinOsc voc => dac;
    freq => voc.freq;
    1 => int attack;
    1/65536.0 => float myGain;
    myGain => voc.gain;
    while (attack || myGain > .001)
       10::ms => now;
      if (attack) {
        myGain*1.25 => myGain => voc.gain;
        if (myGain >= amp) {
          0 => attack;
      else {
        myGain*.99 => myGain => voc.gain;
     spork ~ playNote(baseFreq, dotGain);
  spork ~ whitneyDot(pitchFuncH(baseFreq,i), durationOfPiece/(i+1), i+1);
majutsu
PostPosted: Wed Nov 01, 2006 4:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks for sharing
interesting
All phenomena are atoms in association and dissociation.
jbum
PostPosted: Fri Nov 03, 2006 9:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
I posted a couple new Whitney Box variations in which I used ChucK to generate the sound.
http://www.coverpop.com/whitney/forums.html?var=v19
http://www.coverpop.com/whitney/forums.html?var=v20
For the stereo variation, I recorded the dac.left and dac.right channels separately. I haven't figured out a way to record in stereo directly to WvOut.
cebec
G2 patch files: 31
PostPosted: Sun Nov 05, 2006 1:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
cool stuff!
Buy N Save
