 Forum index » Clavia Nord Modular » g2ools utilities
How to set dx2g2 in neutral?
Page 1 of 1 [2 Posts]
torsig1967
PostPosted: Wed May 09, 2007 11:08 pm    Post subject: How to set dx2g2 in neutral? Reply with quote  Mark this post and the followings unread
In the FX-area of DX7 patches converted with dx2g2 there are some extra effects added. Obviously some - like the reverb - has nothing to do with the original DX7 sounds and I wonder how to set these effects to come as close to the original as possible. I guess Fat and Reverb should be removed but how about the one called PostF? Is this some kind of attemt to mimic limitations in the original DX? I can't hear that it makes a very big difference, maybe it's only on certain sounds?
3phase
G2 patch files: 138
PostPosted: Fri May 11, 2007 3:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
the fx section is a compromise between a version G2ian made, one with reverb and one i made that mimics the more dirty sound of a real dx 7...
Its ratehr optional and more as a placeholder for own experiments ... you can remove it or make your own in the dx.pch2 file in the g2ools folder...that is the blank that is used...
because the fx area is not part of the conversion you can throw in everything you like..or nothing..
Niio1
