midi sporking?
Page 1 of 1 [3 Posts]
openloop
PostPosted: Thu Sep 20, 2007 12:06 am    Post subject: midi sporking? Reply with quote  Mark this post and the followings unread
so i've got the example mandolin up and running from the STK with midi.
i have a small problem though that i can't seem to wrap my head around.
with i < 40 set below (by default) i can play 40 notes before playback stops
// spork handlers, one for each voice
for( 0 => int i; i < 40; i++ ) spork ~ handler();
i tried changing the loop with i < 1 and got exactly 1 note of playback
is sporking the right thing to do here? how would i go about getting the playback to reuse the handlers?
here is the complete code. thanks in advance.
// name: polyfony.ck
// desc: polyfonic mandolin model
// by: Ananya Misra and Ge Wang
// send all complaints to prc@cs.princeton.edu
// device to open (see: chuck --probe)
3 => int device;
// get from command line
if( me.args() ) me.arg(0) => Std.atoi => device;
MidiIn min;
MidiMsg msg;
// try to open MIDI port (see chuck --probe for available devices)
if( !min.open( device ) ) me.exit();
// print out device that was opened
<<< "MIDI device:", min.num(), " -> ", min.name() >>>;
// make our own event
class NoteEvent extends Event
int note;
int velocity;
// the event
NoteEvent on;
// array of ugen's handling each note
Event @ us[128];
// the base patch
Gain g => JCRev r => dac;
.1 => g.gain;
.2 => r.mix;
// handler for a single voice
fun void handler()
// don't connect to dac until we need it
Mandolin m;
Event off;
int note;
while( true )
on => now;
on.note => note;
// dynamically repatch
m => g;
Std.mtof( note ) => m.freq;
Std.rand2f( .6, .8 ) => m.pluckPos;
on.velocity / 128.0 => m.pluck;
off @=> us[note];
off => now;
null @=> us[note];
m =< g;
for( 0 => int i; i < 1; i++ ) spork ~ handler();
// infinite time-loop
while( true )
// wait on midi event
min => now;
// get the midimsg
while( min.recv( msg ) )
// catch only noteon
if( msg.data1 != 144 )
continue;
// check velocity
if( msg.data3 > 0 )
// store midi note number
msg.data2 => on.note;
// store velocity
msg.data3 => on.velocity;
// signal the event
on.signal();
// yield without advancing time to allow shred to run
me.yield();
else
if( us[msg.data2] != null ) us[msg.data2].signal();
drooler
PostPosted: Mon Sep 24, 2007 7:40 pm    Post subject: easier way... Reply with quote  Mark this post and the followings unread
http://wiki.cs.princeton.edu/forums.html/EasyMIDI.ck
openloop
PostPosted: Mon Sep 24, 2007 10:23 pm    Post subject: Re: easier way... Reply with quote  Mark this post and the followings unread
Hey thanks, that's really what I was looking for.
I found by taking out this part of the first loop I could work around it:
off @=> us[note];
off => now;
null @=> us[note];
m =< g;
Buy N Save
