strange Editor bug
Page 1 of 1 [7 Posts]
Ivity
G2 patch files: 57
PostPosted: Fri Sep 21, 2007 11:35 am    Post subject: strange Editor bug Reply with quote  Mark this post and the followings unread
One or two times in a week when I launch G2 editor he shows this error:
"Version mismatch, Nord Modular G2 Rack V1.40" and doesn't see my new G2 Expanded 3Octave Keyboard, the only way to solve this problem is to switch on/off G2, then editor launches.
Sometimes, when I launch Synth Updater he shows Nord Modular G2X, but mine is 3 octave expanded Nord Modular G2, non G2X Sad
What could it be? Confused
Computer: Windows XP SP2
Mobo ASUS P5PL2
P4 3.2 Ghz Single Core
[update] On the other computer situation is the same Sad
Igor
www.myspace.com/phoiod
www.bl-project.com/Ivity.html
Ivity
G2 patch files: 57
PostPosted: Wed Sep 26, 2007 5:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Problem solved: I sorted my synth out in local Clavia distributor Very Happy
Seems like that was a USB hardware issue in Nord Modular G2 synth Sad
Igor
Audio files: 116
G2 patch files: 317
PostPosted: Wed Sep 26, 2007 5:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Do you know what they did to fix it?
Ivity
G2 patch files: 57
PostPosted: Wed Sep 26, 2007 7:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Well, Jan, I don't know, because they gave me a new synth......
But they said, that I'm not the first men with this kind of problem Sad
Igor
Audio files: 116
G2 patch files: 317
PostPosted: Wed Sep 26, 2007 7:51 am    Post subject: Reply with quote  Mark this post and the followings unread
Right, that bad Shocked ... I know you are not the first, but I'm curious as to what the problem is (and if it might hit me one day ... Wink )
Good it got solved for you anyway Very Happy
Ivity
G2 patch files: 57
PostPosted: Wed Sep 26, 2007 8:16 am    Post subject: Reply with quote  Mark this post and the followings unread
I hope, Jan, that this problem will not hit you Shocked
I think that it was a corrupted data chip, which served USB communication between synth and PC driver (this explains G2 driver madness) Confused
Igor
Audio files: 116
G2 patch files: 317
PostPosted: Thu Sep 27, 2007 1:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ah, ok, that seems to make sense indeed, thanks !
Niio1
