nord lead 2 *problem*: infinite sustain
Page 1 of 1 [10 Posts]
dr nigel
PostPosted: Wed Oct 24, 2007 9:09 am    Post subject: nord lead 2 *problem*: infinite sustain
Subject description: arrrgh!
hello nord enthusiasts!
i'm writing in regards to the nord lead 2 i've owned and gigged with on a regular basis for over 5 years. i love this instrument dearly, and discover more and more about it every time i play it. i've had it long enough to learn how to do basic (mechanical) surgeries and periodical cleanings.
lately, however, it has begun "locking" notes into an infinite sustain. oddly enough it only happens with patches on 'Bank A', but will do the same to any bank or patch dialed in after this happens. the effect is as though the 'release' knob were cranked all the way to 10. (or maybe even 11?)
the note does break when i hit the panic button (shift > panic); but will immediately revert back to full sustain mode upon the next note-on. this has happened on stage more times lately than i would like. i have no choice but to reboot the instrument on the spot, or else the result is total chaos.
this used to happen on rare occasion, and would "heal itself" whenever i would reboot; but lately it has been happening much more frequently, which displeases me greatly. Mad
has this happened to anyone else before?
if so -- any potential solutions or ideas...?
regards,
neil
Audio files: 116
G2 patch files: 317
PostPosted: Wed Oct 24, 2007 9:13 am    Post subject: Reply with quote  Mark this post and the followings unread
welcome neil,
sounds like a keyboard problem to me as I had it with the Nord Modular (Classic). I ended up replacing the keyboard (after trying to repair it a few times).
dr nigel
PostPosted: Wed Oct 24, 2007 9:20 am    Post subject: Reply with quote  Mark this post and the followings unread
hmmm... was hoping it wouldn't come down to that...
Audio files: 116
G2 patch files: 317
PostPosted: Wed Oct 24, 2007 9:23 am    Post subject: Reply with quote  Mark this post and the followings unread
I guess the good news is that AFAIK it's a fairly standard keyboard, Wout will have the details once he chimes in here - or so I hope Very Happy
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Wed Oct 24, 2007 10:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Pom-pom-pom-pipy-dom...
Anything to do today?
Let's chime in on e-m.com...
Well, well...
Better to check with Calvia support, but I think the keyboard is a http://www.fatar.com/Pages/TP_7BA.htm.
Hmm...
The link doesn't work, so better surf from http://www.fatar.com/
Replacement is easy to do. I probably know how to open the synth?
Also, hanging notes also will stick their heads out when the synth is receiving to much Midi data. Better check this first.
Wout
dr nigel
PostPosted: Wed Oct 24, 2007 11:00 am    Post subject: Reply with quote  Mark this post and the followings unread
could a hanging note really be a mechanical issue?
it seems like it's more in the processing end of the synth, than the keyboard mechanism...
as far as midi data, that definitely makes sense.
is the nord's midi system something i can feasibly "disengage" ?
Audio files: 116
G2 patch files: 317
PostPosted: Wed Oct 24, 2007 11:55 am    Post subject: Reply with quote  Mark this post and the followings unread
By pulling out the MIDI cables I guess and see if the problems stays or goes away.
And yes a keyboard can cause hanging notes when the key contact makes but will not break, which is the problem that I had on the NM. And that's much more likely than the software of the machine having changed Very Happy
dr nigel
PostPosted: Wed Oct 24, 2007 7:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
well then my next question is ....
where can i order a FATAR TP/7BA?
i see they are based out of italy.
anyone happen to know if they have distributors in the US?
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Thu Oct 25, 2007 1:59 am    Post subject: Reply with quote  Mark this post and the followings unread
I should make contact with Clavia first. They can tell where to get it, if it is the right one or maybe... they send you a new keyboard, after payment, I think Wink
After all this forum isn't the help desk Smile
Wout
nordragious
PostPosted: Sun Nov 04, 2007 2:07 am    Post subject: Reply with quote  Mark this post and the followings unread
I would suggest that you check the distributor part of clavias website and locate the distributor in your country...
That should give you a chance to get your hands on a brand new keyboard Very Happy
