 Forum index » Clavia Nord Modular » G2 Performances - Experimental
Poly Effects - Chorus
Page 1 of 1 [6 Posts]
iPassenger
G2 patch files: 78
PostPosted: Tue Sep 30, 2008 12:56 pm    Post subject: Poly Effects - Chorus
Subject description: Not really experimental but seemed best place to put it.
This isn't really experimental as such, more proof of concept.
It occured to me whilst messing with chorus units in the VA area that why not just use this area to get a thick chorus effect from just one chorus unit. The basis for the chorus unit I stole from Dave P, I think.
I have added a compressor and Rob's tilt filter for extra effect in the FX area and a basic Mono synth to drive it from slot A (chorus in Slot B). So basically I have just stolen a load of ideas of other folks.. cheers Smile
You could easily patch the same with all manner of similar poly processors to great effect (need more words to avoid these puns).
Apologies if everyone is already doing this and I'm just Mr Johny Come Lately. Smile
**I appreciate that as the synth is mono it could have been built in the FX area (and could therefore be a .pch instead of .prf) but I wanted to be able to run any synth through the poly effect.**
Fat Mono Chorus.prf2
 Filename:  Fat Mono Chorus.prf2
 Filesize:  5.28 KB
 Downloaded:  721 Time(s)
iP (Ross)
ian-s
Audio files: 42
G2 patch files: 584
PostPosted: Tue Sep 30, 2008 1:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice
dorremifasol
Audio files: 6
G2 patch files: 47
PostPosted: Thu Oct 02, 2008 11:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Ross, sounds great! Have you realized that you can put all the Slot B content in the Slot A, making a one slot patch instead of a two slot performance?
Fat Mono Chorus.pch2
one slot version of iPassenger's Fat Mono Chorus
 Filename:  Fat Mono Chorus.pch2
 Filesize:  3.35 KB
 Downloaded:  691 Time(s)
Albert
iPassenger
G2 patch files: 78
PostPosted: Fri Oct 03, 2008 12:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Cheers fellas.
Albert,
Yeah I realised, that see my **comment**above. Smile But my thinking was as a performance anyone can use any synth they like with it, e.g. one of their own, be it a mono or a poly synth. Wink
Tried to do a similar thing with the standard Phaser + Flanger modules but I seem to remember it didn't work.. perhaps the incorporated controlling LFOs in these modules are mono... though I could be wrong?
So perhaps patching your own custom flanger/phaser using the filter modules and poly lfos would be the answer.. Another thought I have had is to make a poly BP filter, with a filter detune controlled by say voice number.. this would allow you to easily construct a sort of spreading filter with out having lots of wiring and several filter modules.
Like I said above I imagine there must be many uses for this kind of processing... i am just having trouble thinking of them all.
Anyone got any other ideas?
iP (Ross)
dorremifasol
Audio files: 6
G2 patch files: 47
PostPosted: Fri Oct 03, 2008 12:52 am    Post subject: Reply with quote  Mark this post and the followings unread
Ooos! sorry I didn't read the last part of your post. I should pay more attention. Embarassed
Albert
iPassenger
G2 patch files: 78
PostPosted: Fri Oct 03, 2008 12:54 am    Post subject: Reply with quote  Mark this post and the followings unread
lol.. no worries. Smile
iP (Ross)
