slo
Joined: Feb 18, 2007 Posts: 200 Location: Victoria, BC
Posted: Sun Dec 02, 2007 6:26 pm Post subject:
Klee Midi |
I know Fonik had a thread going somewhere to integrate midi to the Klee, and I think he did indeed do it. I have built this little sync board for a Dr-55 Dr.Ryhthmn and it works great. I was thinking it would be a simple SDIY approach to add midi clock to the Klee. I'm a little hazy on how the Klee starts and stops, haven't studied the schematic yet, but I'm sure this little fella could do the trick.
What do you guys think?
http://members.iinet.net.au/~ben.riggs/electronics/synthdiy/bossdr55.html Last edited by slo on Sun Dec 02, 2007 6:33 pm; edited 2 times in total |
Danno Gee Ray
Joined: Sep 25, 2005 Posts: 1332 Location: Telford, PA USA
Posted: Sun Dec 02, 2007 6:29 pm Post subject:
404
The page you are looking for cannot be found. |
slo
Posted: Sun Dec 02, 2007 6:33 pm Post subject:
Sorry, try now
George |
Joined: Apr 03, 2004 Posts: 19620 Location: The Netherlands, Enschede
Audio files: 116
G2 patch files: 317
Posted: Sun Dec 02, 2007 6:34 pm Post subject:
I fixed the link. _________________ Jan |
Audio files: 116
G2 patch files: 317
Posted: Sun Dec 02, 2007 6:35 pm Post subject:
| Blue Hell wrote: | | I fixed the link. |
Guess we both did  _________________ Jan |
Scott Stites
Joined: Dec 23, 2005 Posts: 4119 Location: Mount Hope, KS USA
Audio files: 96
Posted: Mon Dec 03, 2007 11:11 am Post subject:
Hey George,
The signal will clock the Klee. Just remember, unmerged gate bus gatge signals will only be as wide as the on time of the signal clocking the Klee. IE, if that clock signal is 5 mS wide, so will your unmerged gate bus gate signal. Trigger outputs will generally be unaffected.
It's not just a matter of thinking "OK, I'll just merge the gate busses", because that function will merge the gate signals as per the "Know the Klee" doc. It's fine for 16X1 single bit sequencing, and 8X2 single bit sequencing with judicious assignment of the gate bus outputs (both with the exception of the Master Gate output), but once you get into Klee Patterns (more than one bit), things are never what they seem.
If you have a circuit that will convert those MIDI triggers to wider times for gating, that would work fine.
urbanscallywag
Posted: Mon Dec 03, 2007 1:22 pm Post subject:
Ahk, I thought this thread was going to be about a Klee with MIDI output.
I don't have enough voltage controlled gear to do anything with a Klee yet.  |
midgetfidget
Joined: Aug 22, 2006 Posts: 84 Location: melbourne, aus
Posted: Mon Dec 03, 2007 8:07 pm Post subject:
| from memory the midibox platform can convert analogue cv to midi, would be handy to be able to sequence midi stuff. |
Scott Stites
Audio files: 96
Posted: Mon Dec 03, 2007 8:12 pm Post subject:
My, my - that would be cool indeed! _________________ My Site |
slo
Posted: Mon Dec 03, 2007 8:15 pm Post subject:
Scott Stites said:
| Quote: | | unmerged gate bus gatge signals will only be as wide as the on time of the signal clocking the Klee. |
Yes, thanks Scott, forgot about this little detail, I remember reading about it in "Know the Klee" and this is what gives the Klee some of it's unusual nature. I 'm going to have to think about this some more. Meanwhile, I have a Klee to build, started on the panel, everything else on the back burner.
George |
Scott Stites
Audio files: 96
Posted: Mon Dec 03, 2007 8:22 pm Post subject:
Seems to me State Machine and/or Fonik might have some ideas on getting gate signals out. Dang it, I'm certain I've discussed this with someone else by PM as well. _________________ My Site |
Audio files: 22
Posted: Thu Dec 06, 2007 10:17 am Post subject:
| Quote: | | Seems to me State Machine and/or Fonik might have some ideas on getting gate signals out. Dang it, I'm certain I've discussed this with someone else by PM as well |
If I understand things correctly, the proposal has been made to use the Klee as MIDI sequencer?
If one were using the Klee to control a MIDI based synthesizer then a couple things would have to be done. First, the GATE lead and trail edges would be utilized to signal the necessary generation of MIDI NOTE ON and NOTE OFF messages. The time interval that brackets these events would sound the note in the MIDI controlled synthesizer. Additionally, since NOTE ON/OFF commands are composed of 3 bytes of data, other information such as NOTE NUMBER representing the pitch of course and NOTE VELOCITY or note loudness would also have to be generated. The note number could be a digital representation of hte CV A,B or A+B outputs. This is the area in which the Klee shines so not capturing these CV's inot the MIDI data stream would be a shame. The velocity can be fixed but probably will sound a bit static so something would have to done with that. This parameter may not be as important since the synthesizer being controlled can put hte additional dynamics onto the sound.
http://www.midi.org/about-midi/tutorial/tutor.shtml
Note On / Note Off / Velocity
In MIDI systems, the activation of a particular note and the release of the same note are considered as two separate events. When a key is pressed on a MIDI keyboard instrument or MIDI keyboard controller, the keyboard sends a Note On message on the MIDI OUT port. The keyboard may be set to transmit on any one of the sixteen logical MIDI channels, and the status byte for the Note On message will indicate the selected Channel number. The Note On status byte is followed by two data bytes, which specify key number (indicating which key was pressed) and velocity (how hard the key was pressed).
The key number is used in the receiving synthesizer to select which note should be played, and the velocity is normally used to control the amplitude of the note. When the key is released, the keyboard instrument or controller will send a Note Off message. The Note Off message also includes data bytes for the key number and for the velocity with which the key was released. The Note Off velocity information is normally ignored.
Hope this helps a bit ....
Bill Last edited by State Machine on Thu Dec 06, 2007 1:51 pm; edited 1 time in total |
Joined: May 16, 2005 Posts: 8905 Location: Birmingham, England, UK
Posted: Thu Dec 06, 2007 11:46 am Post subject:
| Scott Stites wrote: | | My, my - that would be cool indeed! |
well, It IS possible
http://www.analoguesystems.co.uk/index2.htm
(edit; stupid flash nonsense- look for RS300 )
edit (again); you can tell how tired I am!  _________________ ACHTUNG!
ZO RELAXEN UND WATSCHEN DER BLINKENLICHTEN. Last edited by v-un-v on Thu Dec 06, 2007 1:51 pm; edited 1 time in total |
Audio files: 22
Posted: Thu Dec 06, 2007 1:46 pm Post subject:
| Quote: | | stupid flash nonsense- look for RS300 |
Tom, now that is an absolutly fantastic module that would most likely fit the bill man !!!! Real nice find !!! The Klee CV's can be inserted into the message with ease it seems!!
Bill |
Posted: Thu Dec 06, 2007 1:55 pm Post subject:
The RS300 has been on my 'hit list' for a while (so have those two lovely looking VCS3 modules also )
Yes AS are the British version of Blacet! But AS do some really tasty modules too! _________________ ACHTUNG!
