Stuck notes
Page 1 of 1 [4 Posts]
AngusHastie
PostPosted: Wed Oct 06, 2004 6:02 am    Post subject: Stuck notes Reply with quote  Mark this post and the followings unread
In the attached patch, the Stereo Delay module in the FX area seems to cause permanent feedback (at low volume but clearly audible through cans) even after the volume envelope has declined to zero. The only way to stop it is to reduce the wet/dry mix.
Any advice??
Angus
Seeker bleeps.pch2
 Filename:  Seeker bleeps.pch2
 Filesize:  1.97 KB
 Downloaded:  737 Time(s)
Audio files: 169
G2 patch files: 319
PostPosted: Wed Oct 06, 2004 6:33 am    Post subject: Reply with quote  Mark this post and the followings unread
What happens when you lower the FB settings ? (have no G2 here)
Jan.
Audio files: 130
PostPosted: Wed Oct 06, 2004 7:30 am    Post subject: Reply with quote  Mark this post and the followings unread
I hear it on my G2 too. Cut back on the FB controls just a tad and this goes away.
AngusHastie
PostPosted: Wed Oct 06, 2004 8:08 am    Post subject: Reply with quote  Mark this post and the followings unread
Agreed - if you reduce the FB, it goes away. I guess it's not too much of a problem so long as you can't hear it through a PA system.
