Is this a sensible way to write a menu in ChucK?
Page 1 of 1 [9 Posts]
Dr. Spankenstein
PostPosted: Fri Jan 18, 2008 6:00 am    Post subject: Is this a sensible way to write a menu in ChucK? Reply with quote  Mark this post and the followings unread
Code:
KBHit CutterMenu;
int Char;
int MenuState;
menu();
fun void menu()
   <<<"Welcome to Rhys' Menu">>>;
   <<<"Select which number you like:">>>;
   <<<"[1]">>>;
   <<<"[2]">>>;
   while (MenuState != 2)
      CutterMenu => now;
      appendChar(CutterMenu.getchar());
   me.exit();   // Is this sensible having this here or will it reach the end of the function and stop automatically when MenuState == 2?
fun void appendChar(int Char)
   if (MenuState == 0)
      //<<<Char>>>;
      if (Char == 49)
         <<<"You have chosen 1">>>;
         <<<"Would you like to choose yes or no?">>>;
         <<<"[Y] or [N]?">>>;
         1 => MenuState;
      if (Char == 50)
         <<<"You have chosen 2">>>;
         2 => MenuState;
         programme();
   if (MenuState == 1)
      if (Char == 121)
         <<<"YES">>>;
         2 => MenuState;
         programme();
      if (Char== 110)
         <<<"NO">>>;
         2 => MenuState;
         programme();
fun void programme()
   <<<"Programme Running">>>;
   10::minute => now;
Also, how do I get rid of those ": (string)" lines that get printed along with the strings? The only way I know of at the moment is to include an integer or other non string!
Thanks,
Rhys
Frostburn
PostPosted: Fri Jan 18, 2008 6:23 am    Post subject: Reply with quote  Mark this post and the followings unread
You can get rid of the :string lines by breaking the string into two or more pieces.
Code:
<<<"I have something on me.">>>;
<<<"We","do","not!">>>;
//output:
//"I have something on me." : (string)
//We do not!
To boldly go where no man has bothered to go before.
PostPosted: Fri Jan 18, 2008 6:41 am    Post subject: Reply with quote  Mark this post and the followings unread
<<<"yes, or like this", "">>>;
while(!machine.crash() ) <<<"all is well">>>;
Dr. Spankenstein
PostPosted: Fri Jan 18, 2008 7:03 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks guys! Very Happy
Rhys
Dr. Spankenstein
PostPosted: Fri Jan 18, 2008 9:54 am    Post subject: Reply with quote  Mark this post and the followings unread
OK menu is almost done but......
How do I store an int from more than one character from the keyboard?
So for example the prompt would say:
"Enter an number?"
ChucK then waits for the enter button to be pressed, reads the ascii code and converts it into an integer which it can then store as a variable?
Code:
if (ASCII == 13)
      User_Entered_Data => int StoredInt;
This is usually pretty basic stuff with programming languages but I cant find anything in the examples, or am I not looking hard enough?
Thanks,
Rhys
PostPosted: Fri Jan 18, 2008 12:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here you go;
ConsoleInput: interim console input (until file I/O)
(use to be hidden Skot object)
see examples/string/readline.ck
Dr. Spankenstein
PostPosted: Fri Jan 18, 2008 12:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Embarassed
EDIT: There doesnt seem to be a parse int type of thing to convert the string token into an integer? An explicit cast doesnt work either Sad
spencer
PostPosted: Mon Jan 21, 2008 7:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
is Std.atoi() what you are looking for? documented here:
http://chuck.cs.princeton.edu/doc/program/stdlib.html
spencer
Dr. Spankenstein
PostPosted: Tue Jan 22, 2008 3:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes I beleive that should do it.
I should have really have seen that myself but lately I've not been seeing the wood for the trees thanks to many a late ChucKing night working on this project.
Thanks Spencer,
Rhys
Music123.com - Customer Appreciation Sale Extended! - Save Up To $80 Off Your Order - Sale Ends Soon!
