Random Synth Generator (beta)
Page 1 of 1 [12 Posts]
lisarael
PostPosted: Mon Feb 11, 2008 7:49 am    Post subject: Random Synth Generator (beta)
Subject description: Just my two cents...
Hi all.
(please note that english is not my native language, i'm apologize for my approximate level)
I've discovered ChucK in a few day, and i'm feel very interesting, because it's what i researched to make the link between my two passions : music an devellopment (i'm webdevelloper in the "real life").
So i begin this week-end to create a little Synth-generator in php/javascript that generate some ChucK scripts...
You can see the beta of it here.
(note that the script is hosted on a local server, so the speed can be a little slow and the page can be not displayed - i will upload the script in a good hosting when it will be ended)
Have a nice day.
Audio files: 22
G2 patch files: 287
PostPosted: Mon Feb 11, 2008 12:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
lisarael
PostPosted: Mon Feb 11, 2008 5:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks.
I made a little upgrade tonight : i put the parameters for all the Oscillators in the script.
Next step will be to implement filters and theirs params in the script.
PostPosted: Mon Feb 11, 2008 5:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cool project!
We're going to have to be careful with our caps to distinguish between Lisa and LiSa from now on! :¬)
More seriously; I don't think I ever saw negative values for Q, are you sure about those? What would this come down to in practice?
Anyway, cool stuff I'm curious to see where this will go, keep it up and if/when you would have the time/desire feel free to link to it on the ChucK WiKi as well.
while(!machine.crash() ) <<<"all is well">>>;
lisarael
PostPosted: Mon Feb 11, 2008 5:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Kassen.
I've juste corrected the negative value for Q, the sound was terrific Wink
So i go to sleep, end coding for today Smile
Now you can add three (or less) filters in the patch, and modifiy the parameters for each of them.
All the filters is not yet listed in my database, i will put it later.
NeKro_Phyl
PostPosted: Tue Feb 12, 2008 2:34 am    Post subject: Reply with quote  Mark this post and the followings unread
Woah, cool project, thx!
lisarael
PostPosted: Tue Feb 12, 2008 2:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
update : adding rythm patterns to the script (i just want to change the style of the rythm patterns-section because i don't love the default styles).
PostPosted: Tue Feb 12, 2008 2:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
nicer & nicer!
Suggestion;
Code:
source.freq( Std.mtof( notes[Std.rand2(0, notes.cap()-1)] ) );
This will make varying the size of notes[] far more convenient if the user later edits the resulting file and this probably also simplifies your own code.
lisarael
PostPosted: Wed Feb 13, 2008 12:38 am    Post subject: Reply with quote  Mark this post and the followings unread
your point of view is nice but in the script, i compute the size of Notes[] in php, so ChucK have not to compute the size on each loop (but i can compute the size one time, before the loop, i will try this).
today, if i found some free times in work, i will do the styles of the rythm-pattern section...
edit: rythm-pattern section is now styled
lisarael
PostPosted: Wed Feb 13, 2008 2:23 am    Post subject: Reply with quote  Mark this post and the followings unread
For my script, i would like to add a switch to allowing the script sending all notes in MIDI format.
I search an example of script for my inspiration, but i not found any script to do this on the web, can you help me ?
PostPosted: Wed Feb 13, 2008 8:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Ah, ok, yes, that's valid. Forget I said anything then.
You could indeed define a integer right after the array and set it to .cap()-1, that might give the best of both worlds.
lisarael
PostPosted: Wed Feb 13, 2008 8:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Yep, this is exactly what i've done after reading your post... It's more efficient for editing the table directly in a text-editor...
Buy N Save
