MISSING BLOCK IDEAS??
Page 1 of 1 [5 Posts]
loss1234
Audio files: 36
PostPosted: Thu Jun 19, 2008 5:55 am    Post subject: MISSING BLOCK IDEAS?? Reply with quote  Mark this post and the followings unread
in the original block ideas there were a few ideas that no one has ever explained (or given a chip number)
1 of 4 Bit adder. is this a 4008??
1 of Pulse Modifier...i can find no 4000 chip listed as this.
1 of Binary Comparator ...what chip is this?
they all sound cool so if anyone knows what chips might make them a reality, please explain!
thanks.
btw, i have recently been putting my guitar through the 4015 with a 40106 as a clock, and its pretty wild. next up, voltage control!
Audio files: 28
G2 patch files: 295
PostPosted: Thu Jun 19, 2008 6:02 am    Post subject: Reply with quote  Mark this post and the followings unread
Binary comparator = "4-bit magnitude comparator" http://www.nxp.com/acrobat_download/datasheets/74F85_2.pdf - you'll want the HC instead of the F variation probably.
jnuaury
PostPosted: Thu Jun 19, 2008 1:13 pm    Post subject: Re: MISSING BLOCK IDEAS?? Reply with quote  Mark this post and the followings unread
a pulse modifier could be made by using a 555 in one-shot mode
it lets you change the pulse length of events but can be useful for limiting rates of events too
and for adding voltage control i think the 4046 PLL VCO is the perfect chip for that purpose especially since you mentioned playing guitar
Adam-V
PostPosted: Thu Jun 19, 2008 3:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yep, the binary adder could be a 4008 - 4 BIT ADDER WITH PARALLEL CARRY
The binary comparator could also be a 4063 - 4 BIT MAGNITUDE COMPARATOR
The pulse modifier was explained further down the block thread but could be as simple as a 555 in one shot mode as suggested by jnuaury or more complex by using a 4528 or 4538 monostable which gives you reset options and positive or negative edge triggering.
Adam-V
Opera Macabre (www.operamacabre.com)
loss1234
Audio files: 36
PostPosted: Thu Jun 19, 2008 5:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks guys-for the great information
as usual
Buy N Save
