Cutoff?
Page 1 of 1 [5 Posts]
crimsonkhatru
PostPosted: Tue Feb 26, 2008 6:46 pm    Post subject: Cutoff? Reply with quote  Mark this post and the followings unread
does anyone know if there is an easy way to make a cutoff control for an oscillator?
DrJustice
PostPosted: Tue Feb 26, 2008 7:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi crimsonkhatru!
welcome to electro-music.com!
Perhaps you could be a little more specific - What kind of oscillator and what exactly do you mean by cutoff?
DJ
crimsonkhatru
PostPosted: Tue Feb 26, 2008 8:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
well to be honest i dont really know what kind of oscillator, its a very simple circuit consisting of two capacitors, a resistor and a transistor wired to one knob for pitch and a power source. by cutoff im looking for that typical frequency cutoff sound that you usually hear when you use a modulation wheel.
ian-s
Audio files: 42
G2 patch files: 617
PostPosted: Wed Feb 27, 2008 2:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Sounds like you want a filter. Based on your description of the oscillator you might like to look for a wha wha pedal circuit. The results will vary depending on the wave shape produced by your oscillator.
crimsonkhatru
PostPosted: Wed Feb 27, 2008 9:34 am    Post subject: Reply with quote  Mark this post and the followings unread
great, i'll give that a try. thanks.
