"Nice Mixer"
Page 1 of 1 [14 Posts]
Freq Band
PostPosted: Sat Apr 19, 2008 11:09 pm    Post subject: "Nice Mixer"
Subject description: typo in schemo?
Ray's "Nice Mixer"
http://www.musicfromouterspace.com/analogsynth/STEREOMIXER2006/STEREOMIXER2006.php
Look at board #2 schematic
....stereo line input 1
versus
stereo line input 2
....R62 and R66 in "line #1" say 150k
but
R69 and R73 in "line #2" say 47k
Is this a mistake ?
or does it serve a purpose ?
They are also shown this way in the parts layout.
thanks,
=FB=
Pehr
Audio files: 9
PostPosted: Tue Apr 22, 2008 12:36 am    Post subject: Reply with quote  Mark this post and the followings unread
Shocked
I have not seen this!
It must be a mistake, right? Confused
Perhaps you should email Ray and ask? Smile
EDIT: It should prob be 150k since the effect return inputs also use 150k.
loxodrom.blogspot.com
loxodrom @ garageband.com Now with new tracks, November '08
My electro-music Klee Sequencer build thread (pictures)
Pehr
Audio files: 9
PostPosted: Tue Apr 22, 2008 7:14 am    Post subject: Reply with quote  Mark this post and the followings unread
I couldn't wait Rolling Eyes
Ray wrote:
...R69 and R73 should be 150K too. I'll fix that on the page.
factus10
PostPosted: Tue Apr 22, 2008 8:10 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm glad I haven't done up the panel for mine yet (I have 2 of these boards). I've already soldered those resistors but that's reasonably easy to change Smile
good catch!
Nothing succeeds like excess.
Freq Band
PostPosted: Tue Apr 22, 2008 11:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks !
I am gutting an old PAIA "9402 Sub Mixer", and using Ray's circuit to re-gut it. Building it point-to-point, using perf board. (sorry Ray, I'll buy some other stuff soon.)
The original owner DIY'ed it, and I thought I could improve on the old PAIA circuit (using a single NE5532) and redo the psu....plus add some effects channels.
Pics soon.
=FB=
Freq Band
PostPosted: Tue May 06, 2008 11:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
Another confusion....
This mixer uses inverting opamps.
The mono channels have an inverting input buffer (opamp), and is sent to the the inverting output opamp.
But the Stereo inputs have no buffer.....which means they go directly to the inverting output opamp(s).
Will the stereo outputs be inverted, by passing through just the inverting opamp, at the output ?
Can someone clarify this for me?
=FB=
Pehr
Audio files: 9
PostPosted: Wed May 07, 2008 12:53 am    Post subject: Reply with quote  Mark this post and the followings unread
You're right. Puzzling... I'll have a look with the scope...
Pehr
Audio files: 9
PostPosted: Wed May 07, 2008 1:54 am    Post subject: Reply with quote  Mark this post and the followings unread
I've also noted that the strereo-and mono-channels have different gain. The mono ones have 10 and for stereo it's 2. I'll prob change my mono channels by replacing the 470k feedback resistors with 100k ones.
I'm also going to add a main vol out.
Pehr
Audio files: 9
PostPosted: Wed May 07, 2008 2:23 am    Post subject: Reply with quote  Mark this post and the followings unread
I would also like the effect send pots to work like my behringer mixer. That is when they're at max it means the signal is wet and at min dry. Not dry/mixed.
Freq Band
PostPosted: Wed May 07, 2008 10:28 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm searching the web for a method for a "proper" wet/dry control.
I know it's out there....
So far, I found this:
This is a balanced design, but I'm trying to understand the theory/wiring idea)
(EDIT link not working)
=FB=
Pehr
Audio files: 9
PostPosted: Wed May 07, 2008 12:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
'The page cannot be found'
I believe it can be solved with a circuit much like the panning, but I'm not sure...
Freq Band
PostPosted: Wed May 07, 2008 6:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
(EDIT link not working to prodigy-pro.com)
(credit and copyright - Keith Andrews, 2005)
If this link doesn't work, I'll PM it to you.
=FB=
Pehr
Audio files: 9
PostPosted: Thu May 08, 2008 12:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
Great link! Thanks! Very Happy
Freq Band
PostPosted: Sun May 11, 2008 10:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Trying this again, so other people know what circuit we're referring to.
I was granted permission to post this by the designer.... Keith Andrews.
http://img.photobucket.com/albums/v379/SSLtech/Crush.gif
=FB=
Top Selling Products! CLICK HERE!
