 Forum index » News... » Apple Computers
Deep Sleep
Page 1 of 1 [3 Posts]
seraph
Editor
Editor
Audio files: 31
PostPosted: Sat Mar 29, 2008 2:29 am    Post subject: Deep Sleep
Subject description: An hibernation Dashboard widget
Deep Sleep is a simple Dashboard widget which allows users to put their computer into hibernation mode, also sometimes called software suspend mode. This widget only works on a limited number of Apple computer models.
arrow http://deepsleep.free.fr/
PostPosted: Sat Mar 29, 2008 6:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
Err....why?
what's wrong with the existing sleep button?? Shocked
ACHTUNG!
seraph
Editor
Editor
Audio files: 31
PostPosted: Sun Mar 30, 2008 1:30 am    Post subject: Reply with quote  Mark this post and the followings unread
v-un-v wrote:
Err....why?
there are 5 different sleep modes on recent Macs accessible from Terminal or thru this widget. I chose the widget Cool
7. Description and modification of the different hibernate modes
When the computer goes into sleeping mode, its behavior depends on a power manage-
ment variable called hibernate mode. The hibernate mode can be set to different values:
• 0 (quick): Default sleep behavior on most Apple computers. RAM is still powered on while
sleeping. Wake up is fast. Safe sleep is disabled.
• 1 (deep): Hibernation behavior. System is totally shut down while sleeping. RAM contents
are dumped to disk. Wake up is slow.
• 3 (safe): Default behavior on Powerbook HD and later computers. RAM is still powered
on while sleeping. Wake up is fast. Safe sleep is enabled, so RAM contents are
also dumped to disk before going to sleep.
• 5 (deep): Same as mode 1 for systems with encrypted virtual memory.
• 7 (safe): Same as mode 3 for systems with encrypted virtual memory.
