converting a signals voltage range?
Page 1 of 1 [2 Posts]
voks
PostPosted: Fri Jul 27, 2012 9:03 am    Post subject: converting a signals voltage range? Reply with quote  Mark this post and the followings unread
Hello
I am fixing an old electronic organ where the top octave generators are broken. I am trying to get a signal from Arduino to match what was originally sent from the IC's. In order to do that i have to convert a squarewave from Arduino going from 0 - 3.3 V to a signal going from -12 - 0 V. I am using the organs 12 V and -12 V supply.
Using an inverting amplifier built with a LM741 op-amp i got an OK result. The squarewave is not really square anymore but it has the correct range of voltage. I am wondering if anyone here has an idea for a simpler or more effective way to do this?
Mikkel
Audio files: 22
PostPosted: Wed Sep 19, 2012 10:16 am    Post subject: Reply with quote  Mark this post and the followings unread
You could just use an amplifier with a faster slew rate. Just make sure you use decoupling capacitors right at your amplifier as now the GBW will be higher.
The 741 is quite slow and thus you need a higher dV/dT or rate of change.
Bill
