key hold for arpeggiator ?
Page 1 of 1 [9 Posts]
synthmad
PostPosted: Thu May 15, 2008 10:15 am    Post subject: key hold for arpeggiator ? Reply with quote  Mark this post and the followings unread
I'm looking at buying an Andromeda.
Is it true that there is no key hold for playing the arpeggiator? meaning you always have to keep the keys pressed manually ? if so is there a way around it ?
thanks.
sunny pedaal
Audio files: 12
PostPosted: Thu May 15, 2008 10:48 am    Post subject: Reply with quote  Mark this post and the followings unread
switchpedal or simple insert an stereoplug with tip and ring connected or put a small piece of paper/carboard between three keys with the middle one depressed.
synthmad
PostPosted: Thu May 15, 2008 1:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm not sure what you mean by switch pedal?
thanks
hogberto
PostPosted: Thu May 15, 2008 1:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
i think he means a foot switch of the 'on/off' type.
see the explanation of foot switches at p.22 of the manual.
i've got a basic foot switch plugged into the 'sustain' socket on the back panel.
if i hold down an arpeggiating chord and then depress the footswitch, the chord keeps arpeggiating (after i've lifted my hand) until i press the footswitch again.
which gives me space to go and fiddle with my modular while the A6 arpeggiates away in the background. Cool
synthmad
PostPosted: Thu May 15, 2008 1:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
great, thats the solution I was looking for Smile
does the Andromeda send MIDI keynote messages with the arpeggiator ?
thanks.
hogberto
PostPosted: Thu May 15, 2008 1:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
i seem to recall that it can't.
but i've not tried it and i can't remember where i read that it can't do this... Sad
sunny pedaal
Audio files: 12
PostPosted: Thu May 15, 2008 1:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
don't think so , neither sequenzerdata
( see " bugs and wishlist , what not to expect from the a6 " topic )
Mark-io
PostPosted: Sat May 17, 2008 3:55 am    Post subject: Reply with quote  Mark this post and the followings unread
the Arpeggiator has a Latch mode (soft knob 7?) but the Sequencer hasnt
sunny pedaal
Audio files: 12
PostPosted: Sat May 17, 2008 4:06 am    Post subject: Reply with quote  Mark this post and the followings unread
indeed.... tunnelvision on my part
