DIY EEPROM programmer?
Page 1 of 1 [4 Posts]
droffset
PostPosted: Thu Mar 25, 2010 8:22 pm    Post subject: DIY EEPROM programmer? Reply with quote  Mark this post and the followings unread
This is a looong way off for me, but in the future I'd like to try making the midi->CV portion of the Paia Fatman in page 4 of the documentation here:
http://www.paia.com/fatman.asp
Really just because I have all the ICs involved already, so might as well try it.
EEPROM programmers are expensive, so has anyone succeeded in making one?
https://docs.google.com/Doc?docid=0AZIwOP-PR9sSZDlidzgzbV8wY3RjenJqanY&hl=en
Edit: Spelling mistakes.
Danno Gee Ray
PostPosted: Fri Mar 26, 2010 4:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
You can buy a Willem Eprom programmer on Ebay dirt cheap. Waaay less than the cost of parts. I got one for around 30 bucks including shipping.
reve
PostPosted: Mon Apr 12, 2010 8:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
If you're really lazy you could just pay someone to burn you the eeproms. I've used this guy who's both friendly and fast:
http://www.eprompro.com/
CYBERYOGI =CO=Windler
PostPosted: Sun Aug 05, 2012 9:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
Many Willem eprommers (e.g. my Willem PRO 4 isp) make trouble with reading or writing non-CMOS parts (old EPROMs, MCS-48 microcontrollers of Casio keyboardss etc.) due to weak voltage switching transistors those cause a voltage drop >0.5V.
You have to replace tiny SMD (or other weak) versions with a power transistor or even a relay switched by the original transistor to stabilize the voltage output.
Code:
MAY THE SOFTWARE BE WITH YOU!
CYBERYOGI Christian Oliver(=CO=) Windler
(teachmaster of LOGOLOGIE - the first cyberage-religion!)
*=============================ABANDON=THE=BRUTALITY==========================*
{http://weltenschule.de/e_index.html}
Niio1
