drum Sequencing for Midi drum machine
Yellow Onion
PostPosted: Mon Jul 14, 2008 6:23 pm    Post subject: drum Sequencing for Midi drum machine Reply with quote  Mark this post and the followings unread
I've written a drum sequencer, it uses hydrogen as the backend drum machine via midi
I've only been chucKing for a week so any tips would be use full
I'm looking at adding the ability to add Chucks instrument
Code:
MidiOut mout;
MidiMsg msg;
        //under GPLv2
   // drum setup for hydrogen's GMkit Drumkit
    //should be the same length as (or a fraction of) "ires"
    //drumline one
[ [   [1.,0.,0.,1.,0.,0.,0.,1.,1.,0.,0.,0.,0.,1.,0.,0.], //kick
    [0.0], //stick
    [0.,0.,0.,0.,0.,0.,1.,0.,0.,0.,0.,1.,0.,0.,0.,0.], //snare Jazz
    [0.0], //Clap
    [0.0], //snare Rock
    [0.], // low  tom
    [0.], //Closed Hi-Hat
    [0.], // mid tom
    [0.,0.,1.,0.,0.,0.,1.,0.], //Pedal Hi-Hat // 1/2 of "ires" means repeated twice during bar
    [0.], //high tom
    [0.], //Open hi-hat
    [0.], //cow Bell
    [1.,0.,1.,.4,.5,0.,1.,0.,1.,.5,0.,.5,1.,0.,.5,1.], //Rid Jazz
    [0.], //Crash
    [0.], //Ride Rock
    [0.] //Crash Jazz
  ], //drumline 2
    [0.0], //stick
    [0.0], //Clap
    [0.0], //snare Rock
    [0.], // low  tom
    [0.], // mid tom
    [0.,0.,1.,0.,0.,0.,1.,0.], //Pedal Hi-Hat; done
    [0.], //high tom
    [0.], //Open hi-hat
    [0.], //cow Bell
    [.8,0.,1.,.4,.52,0.,.7,0.,8.,.5,0.,.5,.8,0.,.5,.8], //Rid Jazz
    [0.], //Crash
    [0.], //Ride Rock
    [0.] //Crash Jazz
  ], //drumline 3
  [ [00.0] ]
    //drumline n
@=> float drumset[][][];
[       // [select drumline from drumset, select tempo]
[0,100],
[0, 60],
[0, 40]] @=> int lineup[][];
100 => int tempo; //tempo of 100bpm (overridden later)
4 => int res; // resolution of counts at 4 per beat eg 1/4 notes
res*4 => int ires; // resolution × 4 beats per bar = drumline length
1::minute/tempo/res => dur T; //count length
T - (now % T) => now;
// check if port is open
//T /
if( !mout.open( 6 ) ) me.exit();
for ( 0 => int ii; ii < lineup.cap() ; ii++) //loop through lineup[][]
    lineup[ii][1] => tempo;
   drumset[lineup[ii][0]] @=> float drum[][];
    for (0 => int i ; i <= ires; i++)// loop through each count
        for(0 => int iii; iii < drum.cap();iii++) //play each instrument
            drum[iii][i%drum[iii].cap()] => float volu;
            if ( volu != 0)
                144 => msg.data1;
                iii+36 => msg.data2;
                (   volu*127 - Std.rand2(0,4) ) $ int => msg.data3;
                mout.send(msg);
      T => now;
