 Forum index » Instruments and Equipment » MIDI Controllers and Interfaces
How to control PitchBend Range ?
Page 1 of 1 [6 Posts]
ReaktorFreak
PostPosted: Fri Oct 10, 2008 1:17 am    Post subject: How to control PitchBend Range ? Reply with quote  Mark this post and the followings unread
I'm kinda stuck here, is there any way to adjust PitchBend range on a device via MIDI ? For example, changing from -2 to +2 semitones to one octave just by sending MIDI message ?
BobTheDog
Audio files: 10
PostPosted: Fri Oct 10, 2008 3:31 am    Post subject: Reply with quote  Mark this post and the followings unread
I don't think there is a standard for this.
What are you trying to set it on?
Andy
ReaktorFreak
PostPosted: Sun Oct 12, 2008 11:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
I just think maybe there's a trick to do it, as i can't find any CC for that. I read in other forum that it can be done with RPN, but it says not all device compatible with it. It's just annoying, the -2 to +2 standard is not suitable for guitar, and i think if there's a way of changing it, i can put that inside the MIDI file i made.
BobTheDog
Audio files: 10
PostPosted: Sun Oct 12, 2008 11:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
I must admit I tend to set the pitch-bend range on a patch basis on the synth I am using.
If you are a midi guitar player may I direct you to the new Sub-Forum "Strings And Things" http://electro-music.com/forum/forum-172.html
Andy
svivens
PostPosted: Mon Oct 13, 2008 7:16 am    Post subject: Reply with quote  Mark this post and the followings unread
you can try the change scale patches from Sensomusic Usine...
it takes the incoming MIDI values,treat them regarding the min and max you select,and create the apropriate values out.
i'm sure you can do the job with this.
it's Standalone or VST, and free!
Usine4 free
ReaktorFreak
PostPosted: Mon Oct 13, 2008 10:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
Andy
Hey, thanks for letting me know about the new sub-forum. I'm not exactly playing MIDI guitar though.
Usine4 free
Thanks ! I'll have a look immediately.
Buy N Save
