 Forum index » Instruments and Equipment » Linux as a music workstation
Bristol Audio Synthesis
Page 1 of 1 [4 Posts]
aquanaut
PostPosted: Sat Oct 07, 2006 11:05 am    Post subject: Bristol Audio Synthesis Reply with quote  Mark this post and the followings unread
Bristol is synth emulation package for Moog, Korg, ARP, Sequential Circuits, Hammond, Oberheim, Yamaha, Roland, Rhodes and Vox instruments. The application consists of a multithreaded audio synthesiser and a user interface called brighton.
https://sourceforge.net/projects/bristol/
seraph
Editor
Editor
Audio files: 31
PostPosted: Sat Oct 07, 2006 12:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
it looks good Exclamation
PostPosted: Sat Oct 07, 2006 2:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
This is a cool piece, have to get electro80 to run it through his paces...he always has comments on moog/arp/etc emulators. Wonder if you can build it on OSX.
nobody
PostPosted: Fri Mar 13, 2009 6:04 am    Post subject: Reply with quote  Mark this post and the followings unread
Is there supposed to be a context menu when you right-click in the open window? I get a blank box that pops up. I'm wondering if you can only start and run one synth at a time from the command line, or if you can switch over to another synth on the fly through a menu (if there is supposed to be one).
It would also be nice to make the control labels a little bigger so it's easier to read from more than a few inches away.
Also, does anyone else have "sticky keys"? When I click on a key, it stays down until I click on it again. But if I patch in vkeybd through jack, I don't have that problem on vkeybd. I couldn't get jack-keyboard to work with it, which would be nice because it's a larger keyboard.
