Drum enhancer/synth
Rix
G2 patch files: 25
PostPosted: Sun Aug 22, 2004 5:05 am    Post subject: Drum enhancer/synth Reply with quote  Mark this post and the followings unread
The idea behind this is simple:
Using the audio ins, filter out the bass drum, snare, tom and hi-hat and distort them a bit (or trigger drumsynth modules), then mix all these signals together with the original signal.
The bass drum is filtered out by a low pass filter, the snare and tom are filtered by a mid band filter and the hi-hats by a hi-pass filter.
All filters are followed by a noise gate.
The best way to try this patch is by connecting a drum machine to the audio ins. You need to carefully tune the filter and noise gate settings.
Richard
DrumEnhance+synth.pch2
Audio in patch for drums.
 Filename:  DrumEnhance+synth.pch2
 Filesize:  1.96 KB
 Downloaded:  775 Time(s)
