Sample and Hold patterns
Page 1 of 2 [26 Posts]
ian-s
Audio files: 42
G2 patch files: 619
PostPosted: Sun Aug 29, 2004 3:39 am    Post subject: Sample and Hold patterns Reply with quote  Mark this post and the followings unread
Two experiments in one patch.
On the audio side, I am fiddling with the integration from the G2 math thread (the little that I actually understood). I wanted to do a wave shaper from triangle to sawtooth to solve the symmetry problem with the LFO sawtooth.
The idea is, the integrator and constant compare module, switch between the triangle and an inverted triangle whenever the slope changes. While testing with a software scope, the switch control signal looked very noisy so I inserted a lowpass filter and things looked better. When adjusting the lowpass cuttoff, the wave sort of morphs from the original triangle shape to the (double frequency) sawtooth. Not spectacular, but it is a sort of interesting effect in the audio range.
The second experiment goes back to the old analogue days. I never owned a decent step sequencer so I had to make do with patterns made by summing the outputs of dividers, and the humble sample and hold. The sample and hold typically is fed a signal from a noise module and clocked by an LFO which gives that cliché, random notes effect. In this patch, the noise is replaced with an audio frequency LFO (LfoC2) and the output is scale quantitized. The result is an ever-changing pattern whose character changes with the difference in frequency. Some extra FM of LfoC2 further randomises things. The rhythm is from a combination of modulated pulse and clocked random triggers.
2 variations
Tri2saw2.pch2
Triangle-Sawtooth wave shaper with S+H sequencer
 Filename:  Tri2saw2.pch2
 Filesize:  4.1 KB
 Downloaded:  1092 Time(s)
Audio files: 130
PostPosted: Sun Aug 29, 2004 9:51 am    Post subject: Reply with quote  Mark this post and the followings unread
Those S/H modules make great sequencers. Better than the step sequencers, IMHO, because they aren't as boring. They always play something new. This setup of yours is an interesting variation on the theme I have never seen before. The addition of the occational glide is fabulous. Variation two cooks. Cool
Wan
G2 patch files: 46
PostPosted: Sun Aug 29, 2004 11:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Very clever patching.
i like the hihats parts how they play through the beat.
Indeed not as boring as stepsequencers.
My turn to be humbled Smile
Grtz Wan
Audio files: 169
G2 patch files: 319
PostPosted: Sun Aug 29, 2004 3:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice one, I'll have to study it a bit better, but meanwhile a little variation came out in the way the notes are selected.
I like the lead sound and didn't dare to touch that.
Jan.
Tri2saw2-bh.pch2
a small variation on g2ian's Tri2Saw2 patch.
 Filename:  Tri2saw2-bh.pch2
 Filesize:  4.34 KB
 Downloaded:  1277 Time(s)
Afro88
Audio files: 12
G2 patch files: 79
PostPosted: Sun Aug 29, 2004 6:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
That's excellent. There's some really intelligible melodies coming from your lfo s+h circuit. At times it sounds like there's a chord progression that the melody is playing to - very cool.
ian-s
Audio files: 42
G2 patch files: 619
PostPosted: Sun Aug 29, 2004 6:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Jan, good tip. A single scale can be a little monotonous.
I'm not a huge fan of this type of sound, sometimes the patch itself leads you.
Afro88
Audio files: 12
G2 patch files: 79
PostPosted: Sun Aug 29, 2004 6:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
I just noticed that outs 3/4 are being used for some of the lead sound- are we supposed to hear these outputs? Or were they simply 'turned off'?
It sounds kinda cool when that output is switched to 1/2...
ian-s
Audio files: 42
G2 patch files: 619
PostPosted: Sun Aug 29, 2004 10:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
oops, I use OUT 2/3 for connection to my PC soundcard so I can see the waves on a software scope.
In this case, its just the direct triangle wave and it's tri-saw mangled version. (see picture, at this point the mangled wave is somewhere between triangle and double frequency sawtooth).
what wave looks like on scope
 Filesize:  11.72 KB
 Viewed:  15858 Time(s)
Audio files: 130
PostPosted: Mon Aug 30, 2004 8:06 am    Post subject: Reply with quote  Mark this post and the followings unread
What softscope are you using. Is it a freebee?
ian-s
Audio files: 42
G2 patch files: 619
PostPosted: Mon Aug 30, 2004 11:47 am    Post subject: Reply with quote  Mark this post and the followings unread
It is from the freeware WIN3.1 wavetools.zip package. Sorry, cant remember the url I downloaded it from (active links are rare I think).
It works well under 98 & XP and the package comes with other tools I havn't tried yet.
Audio files: 169
G2 patch files: 319
PostPosted: Mon Aug 30, 2004 12:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
I found one Russian site :
http://ra4ffq.narod.ru/download/WaveTools.zip
it seems to be the thing, but it's a _very_ slow link, something like a quarter of an hour for half a megabyte.
[Note : WaveTools is also available for download from http://electro-music.com/forum/topic-3257.html ]
Jan.
Audio files: 169
G2 patch files: 319
PostPosted: Mon Aug 30, 2004 4:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes it does, lead you I mean, me I mean.
I deconstructed things a bit more ... great potential once the verb is removed :-)
(I hope you don't mind me doing this to your patch, it was a popular activity once on the NM mailing list, this patch changing game, that I try to re-establish. It means that I got inspired by your patch even when things might have gone beyond recognition)
Jan.
some-1.prf2
some combined variations on the tri2saw2 patch by g2ian
 Filename:  some-1.prf2
 Filesize:  13.91 KB
 Downloaded:  1222 Time(s)
Audio files: 130
PostPosted: Mon Aug 30, 2004 5:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
This is great music to change servers by... Wink
Audio files: 130
PostPosted: Mon Aug 30, 2004 5:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
That WaveTools thing is excellent. Works great on my XP machine with the MOTU 828MKII. Think I'll post it on the How To forum. It may be faster for some people there...
ian-s
Audio files: 42
G2 patch files: 619
PostPosted: Tue Aug 31, 2004 1:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sounds like a good game Jan, I like the beautifully tortured sounds in your version.
Don't know if it is allowed but I am posting a prf myself. This one also uses one of Tim's patches (modified to keep in the spirit of the game). I also nicked Robs 48K clock for the original differentiator (I am still thinking of other uses for this sub circuit, switch changes state depending on direction of slope, ummm). Also implemented a group of scalers for variation.
A chance to test uploading on the new server as well.
Edit - Uploading works well. Great work thanks Howard.
slowtb.prf2
slow performance using tri2saw patch
 Filename:  slowtb.prf2
 Filesize:  12.45 KB
 Downloaded:  1002 Time(s)
Audio files: 130
PostPosted: Tue Aug 31, 2004 2:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wow, this one is really beautiful, Ian. It has a lot of drama and suspense. It could be the soundtrack of a movie. I'm on the edge of my seat waiting for somthing to snap and someone to scream. Shocked
Audio files: 169
G2 patch files: 319
PostPosted: Tue Aug 31, 2004 3:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sure you can, why not ? And it''s a good one I think.
Funny I also had this StringCheesy patch in mind to do 'something' with, I like the liveliness of its sound.
The 48 KHz .. I saw it as well and I noted the unused inverter to be connected, and wondered why ... . It's used to get it to run at audio rate I suddenly realize (and I now know why certain experiments I did with this circuit failed). Aha !
I knew Rob wouldn't do a useless thing ...
Jan.
Afro88
Audio files: 12
G2 patch files: 79
PostPosted: Tue Aug 31, 2004 5:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ian, that's a fantastic performance! Like Mosc said, it could really be part of the soundtrack for a movie. Top notch.
At the moment I'm trying to figure out how your chords work... not having much luck though Embarassed I've noticed that your bass notes sympathise with the chords as well. It's a very complex set up. Something to do with the mux?
ian-s
Audio files: 42
G2 patch files: 619
PostPosted: Tue Aug 31, 2004 7:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the kind words
The chords are sort of tacked on the side. The bass generator is the same as the original except that the S+H output is taken to three KeyQuant modules, these get fed into the eight in mux (using all eight inputs allows a crude influence over probability) The mux is switched by RndPattern1 clocked by ClkDiv2, fed from the master LFO (lfoC3).
ClkDiv2 also supplies RndTrig3 pulses that directly gate the two noteSend modules in the chord section. The output from the Bass mux at the time the gate goes high offsets the note values in the chord. The S+H here is redundant Embarassed , as the noteSend will effectively latch the value anyway.
The two notes are sent to SlotB which via the notezone module, passes then also to slotD for layering.
Not the result of careful planning, more like fiddle till it sounds ok, adding more modules as a last resort.
These type of sampled lfo patterns are by themselves, quite repetitive. This one is randomised by x-modulation and slow modulation applied to the sampled lfoC2, use the mixer above to vary the variation. I think this is one of the few practical applications of the aliasing effect.
Afro88
Audio files: 12
G2 patch files: 79
PostPosted: Tue Aug 31, 2004 8:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
Very nice. Thanks for the explanation Ian Very Happy I thought the chords were transposed with the bass... that's really quite a clever way of doing it. I'm not very experienced with programming noodles (as you can tell I program alot of dance based stuff) but every now and then a patch like this one comes along that inspires me to have another crack at creating a worthwhile noodle... perhaps this time?
Audio files: 130
PostPosted: Tue Aug 31, 2004 8:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
There are lots of dance based noodles.
Afro88
Audio files: 12
G2 patch files: 79
PostPosted: Tue Aug 31, 2004 10:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hmmm.. I may have to dig around the G1 patch archives for a bit. With the new module reference list it shouldn't be too hard to convert some over to the G2. Smile
Audio files: 169
G2 patch files: 319
PostPosted: Wed Sep 01, 2004 1:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
Some more spin-off.
Jan.
04-015-001.prf2
Another spin-off from g2ian's Tri2Saw [atch.
 Filename:  04-015-001.prf2
 Filesize:  12.56 KB
 Downloaded:  1283 Time(s)
Audio files: 130
PostPosted: Wed Sep 01, 2004 1:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
Whoa, this goes from being humorus to being tortuous. Shocked
Not one of my favorites, Jan. I'm sorry
Audio files: 169
G2 patch files: 319
PostPosted: Wed Sep 01, 2004 5:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sorry to hear you don't like it ... it's better than the previous one though in my humble obsession. It has more diversity, and it fits my mood better.
I hope this mood will change though now that my summer holiday started, finally, today. I've been dragging myself for a while.
Draging myself job-wise, the presentation of the noodle radio went quite well last weekend. some liked it others didn't, but I got asked to do something like it for a picture exhibition by a painter who's work I liked. I'm happy with that.
Anyway, holiday .. tomorrow I'll be hanging around still till afternoon or so, after that I'll be out for about ten days. Just the usual trip when I need to be away, to Ireland
Jan.
