 Forum index » Instruments and Equipment » Reaktor
Mixer in-ports is not working
Page 1 of 1 [3 Posts]
tsjca213
PostPosted: Thu Jan 29, 2009 2:38 pm    Post subject: Mixer in-ports is not working Reply with quote  Mark this post and the followings unread
I am the definition of a newbie, this is my first time using reaktor, so i am sorry for asking probably a very dumb question. I was going through a tutorial and got stuck in the middle of it, i know almost nothing yet, so sorry for not being able to describe my problem well enough.
Within the instrument there is a notepitch and a gate going through two macro-oscillators, both macro-oscillators is going into a macro-mixer that is supposed to go out to the mono.
Here is inside my instrument:
The problem is within the "Macro-mixer" with a orange square in the corner:
The "In" knobs at the mixer is crossed out, which i can't figure out in the tutorial i took, here is the part of the tutorial i do not understand:
Here is the link to the tutorial if there's any information left out: http://electrictrumpet.com/SympleSynth/sstutorialosc.htm
Thank you very much for answering!
ReaktorFreak
PostPosted: Sat Jan 31, 2009 9:02 am    Post subject: Reply with quote  Mark this post and the followings unread
It's quite simple, in the tutorial the 'mixer' macro is set to polyphonic, while in your instrument it's set to monophonic. Simply change the macro to polyphonic to make it works.
tsjca213
PostPosted: Sat Jan 31, 2009 9:04 am    Post subject: Reply with quote  Mark this post and the followings unread
Aaaah.. Offcourse, thank you very much!
