New to Chuck: UAna Vocoder = everything vocoded
pespes
PostPosted: Sat Apr 18, 2009 6:06 pm    Post subject: New to Chuck: UAna Vocoder = everything vocoded Reply with quote  Mark this post and the followings unread
Hi ChucK'ers,
I found a great piece of code on someone's site that allows you to use an external wav file as a "template" to vocode mic input. It works perfectly, but any additional shreds that I add to the VM also get vocoded. I would like the vocoder to only modify the left adc input....
Anyhow, I don't fully understand what the vocoder shred is doing, and would love some from someone familiar with ChucK's UAna system.
======* See attached .ck file!, or read on. *======
Code:
// implementation of FFT vocoder: (code not fully understood - P)
SndBuf carrier => FFT fft_c => blackhole; // music signal
"samples/insect_wav/insect_8.wav" => carrier.read; // file,of course.
adc.left => PoleZero dcblock => FFT fft_m => blackhole; // voice signal
IFFT ifft => PoleZero dcblock2 => dac;
0.999 => dcblock.blockZero;
0.999 => dcblock2.blockZero;
// fft/ifft constants
2500 => int FFT_SIZE => fft_c.size => fft_m.size => ifft.size;
FFT_SIZE => int WIN_SIZE;
FFT_SIZE/8 => int HOP_SIZE;
Windowing.blackmanHarris( WIN_SIZE ) => fft_m.window => fft_c.window => ifft.window;
// spectrum array:
complex spectrum_c[WIN_SIZE/2];
complex spectrum_m[WIN_SIZE/2];
// temp variables:
polar temp_polar_m, temp_polar_c;
// compute srate
second / samp => float srate;
1 => carrier.loop;
//1 => modulator.loop;
while( true )
    // take ffts:
    fft_m.upchuck();
    fft_c.upchuck();
    fft_m.spectrum( spectrum_m );
    fft_c.spectrum( spectrum_c );
    // convert complex form to polar, assign magnitudes & back to complex:
    for( 0 => int i; i <spectrum_m> temp_polar_m;
        spectrum_c[i]$polar => temp_polar_c;
        temp_polar_m.mag => temp_polar_c.mag;
        // store values. Re-use carrier's spectrum:
        temp_polar_c$complex => spectrum_c[i];
    ifft.transform( spectrum_c );
    HOP_SIZE::samp => now;
vocode_left.ck
 Filename:  vocode_left.ck
 Filesize:  1.39 KB
 Downloaded:  152 Time(s)
