<on air> PHOBoS presents: There is no show, or is there ?
Machine.add Classes - undefined type 'MyClass'
Page 1 of 1 [4 Posts]
pfuentes
PostPosted: Sun Nov 25, 2012 3:12 am    Post subject: Machine.add Classes - undefined type 'MyClass'
Subject description: Problem adding classes
Hi, this problem has been bugging me for the last three days and i'm pretty sure its a very simple fix, which pisses me off...but I have a Notes class for calling frequencies by their note names and register and that tests out fine within the same chuck file, but when i try to Machine.add("Notes.ck") to use within a new chuck file, which also containing my melodic code, chuck doesn't recognize my class Notes. I have Notes x; set, yet i still get [melody]:line(9): undefined type 'Notes'...
why is this happening? i've tried public/private class, and still get the same response. My miscellaneous is also set accordingly. Any ideas?
pizzas
PostPosted: Tue Feb 05, 2013 7:34 am    Post subject: Reply with quote  Mark this post and the followings unread
hi pfuentes. i know it's been a while since you asked, but if you're still wondering...
looking at this example for classes (from here), it seems that public classes in a separate file need to be called at the same time you start your main program. in other words, you need to say "chuck main.ck class.ck" for it to work. sporking and Machine.add are no good.
but i found your question because i have the same question. the examples are pretty old. is there a better way now?
GrandJu
PostPosted: Thu Feb 07, 2013 10:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi and Welcome to ChucK,
I don't know exactly how this is manage internaly but I have some practical knwoledge about it.
It is not possible to add your class in your main program directly:
for example , main.ck:
Code:
Notes note;
will not work because the main.ck will be parsed entirely first. Then Notes.ck will be loaded after as it is a child process.
You may have a top script that will call the two process one after the other
top.ck:
Code:
Machine.add("main.ck")
Have fun,
Ju
pizzas
PostPosted: Tue Feb 12, 2013 2:21 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks ju! that makes total sense. thanks a lot.
