FlowStone - Graphical Programming Software
datapark
PostPosted: Sun Dec 19, 2010 9:32 am    Post subject: FlowStone - Graphical Programming Software
Subject description: FlowStone is an advanced version of Outsim's Synthmaker - Designed to work with outboard hardware
So I'm reading up on another forum about various soft synth issues and find that SynthMaker 2 has been released, and as I'm reading up on that I see that Outsim (SMs makers) have expanded.
http://www.dsprobotics.com/index.html
This is when I read about FlowStone - And figured some of you might be interested.
I know this particular DIY community has is bent in favor of analog instruments and effects, but I'm sure even some of you may appreciate what is possible using this particular piece of software.
Essentially, if you've ever used SynthEdit or Synthmaker or that MacOS equivalent I can't quite recall right now... this program is pretty much the same. Except its not geared specifically at creating VST instruments and effects but is more about software control of hardware systems.
More on point with this forum is the "embedded" solution - basically a small form factor mother board capable of hosting modern day CPUs that will load an embedded Windows designed to run just your FS program... so create you custom synth, efx, etc, add control options, install onto embedded board, & voila - custom digital hardware with all the bells and whistles you can think to add...
datapark
