CHROMA templates
Page 1 of 1 [13 Posts]
davep
Audio files: 10
G2 patch files: 73
PostPosted: Mon Jan 03, 2005 5:52 pm    Post subject: CHROMA templates Reply with quote  Mark this post and the followings unread
Hi all,
As mentioned in the G2 forum discussion on detuning oscs, here is the set of Chroma template patches I made a while back to replicate the Chroma sound, along with a few complete patches based on these templates.
Note that the Uni Lead and Uni Bass patches are a little different - they don't replicate the Chroma filter sound exactly, but they are attempts to replicate the Chroma's massive 'unison' mode. To use these, load the same patch into two slots on the NM1, and use knob1 to set each slot to a different amount of detuning. Huge!
Howard & Jan - It seems that I can only attach three files at a time (hence the multiple emails). Is that intentional?
Dave Peck
CHROMA 12dB res=2.pch
 Filename:  CHROMA 12dB res=2.pch
 Filesize:  1.05 KB
 Downloaded:  148 Time(s)
CHROMA 12dB res=4.pch
 Filename:  CHROMA 12dB res=4.pch
 Filesize:  930 Bytes
 Downloaded:  151 Time(s)
CHROMA 12dB res=6.pch
 Filename:  CHROMA 12dB res=6.pch
 Filesize:  1.22 KB
 Downloaded:  171 Time(s)
Dave Peck
davep
Audio files: 10
G2 patch files: 73
PostPosted: Mon Jan 03, 2005 5:54 pm    Post subject: More Chroma Reply with quote  Mark this post and the followings unread
more...
CHROMA dual filter min res.pch
 Filename:  CHROMA dual filter min res.pch
 Filesize:  1.21 KB
 Downloaded:  147 Time(s)
Chroma Pad mode 1+warmth.pch
 Filename:  Chroma Pad mode 1+warmth.pch
 Filesize:  2.87 KB
Chroma Pad mode 13.pch
 Filename:  Chroma Pad mode 13.pch
 Filesize:  2.63 KB
 Downloaded:  157 Time(s)
Dave Peck
davep
Audio files: 10
G2 patch files: 73
PostPosted: Mon Jan 03, 2005 5:57 pm    Post subject: more... Reply with quote  Mark this post and the followings unread
more...
Chroma Pad mode 13+warmth1a.pch
 Filename:  Chroma Pad mode 13+warmth1a.pch
 Filesize:  2.95 KB
 Downloaded:  146 Time(s)
Chroma Res 6+2 Pad.pch
 Filename:  Chroma Res 6+2 Pad.pch
 Filesize:  3.31 KB
 Downloaded:  135 Time(s)
Chroma Rez Brass1.pch
 Filename:  Chroma Rez Brass1.pch
 Filesize:  2.42 KB
 Downloaded:  142 Time(s)
Dave Peck
davep
Audio files: 10
G2 patch files: 73
PostPosted: Mon Jan 03, 2005 5:59 pm    Post subject: more... Reply with quote  Mark this post and the followings unread
more...
Chroma Saw Pad1.pch
 Filename:  Chroma Saw Pad1.pch
 Filesize:  2.96 KB
 Downloaded:  132 Time(s)
CHROMA series filters res=2.pch
 Filename:  CHROMA series filters res=2.pch
 Filesize:  1.47 KB
 Downloaded:  144 Time(s)
CHROMA series filters res=0.pch
 Filename:  CHROMA series filters res=0.pch
 Filesize:  1.11 KB
 Downloaded:  143 Time(s)
Dave Peck
davep
Audio files: 10
G2 patch files: 73
PostPosted: Mon Jan 03, 2005 6:00 pm    Post subject: more... Reply with quote  Mark this post and the followings unread
more...
CHROMA series filters res=4.pch
 Filename:  CHROMA series filters res=4.pch
 Filesize:  1013 Bytes
 Downloaded:  130 Time(s)
CHROMA series filters res=5.pch
 Filename:  CHROMA series filters res=5.pch
 Filesize:  1.14 KB
 Downloaded:  137 Time(s)
Dave Peck
davep
Audio files: 10
G2 patch files: 73
PostPosted: Mon Jan 03, 2005 6:01 pm    Post subject: last two Chroma patches Reply with quote  Mark this post and the followings unread
Last two...
Chroma Uni Bass.pch
 Filename:  Chroma Uni Bass.pch
 Filesize:  3.6 KB
Chroma Uni Lead.pch
 Filename:  Chroma Uni Lead.pch
 Filesize:  2.75 KB
 Downloaded:  140 Time(s)
Dave Peck
Audio files: 116
G2 patch files: 317
PostPosted: Mon Jan 03, 2005 6:15 pm    Post subject: Re: CHROMA templates Reply with quote  Mark this post and the followings unread
I don't know about that, Howard will have to answer it.
And wow, once you get the hang of it you for sure can post faster than anyone can download :-)
I'lm going to cross link the topics a bit, the one and only usefull contribution I can make right now, thanks Dave !
Also see : http://electro-music.com/forum/post-28464.html
Jan.
Audio files: 107
PostPosted: Mon Jan 03, 2005 9:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
The forum software has a limit that is adjustable that is set to 3 by default. I think the low number is to protect the server from an attack that loads zillions of attachments. I tend to think 3 is probably all one should reasonably expect to work reliably over an HTTP connection.
varice
G2 patch files: 46
PostPosted: Mon Jan 03, 2005 9:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hmmm... somehow the patch files I downloaded got corrupted, the Modular Editor would not load them. I opened a couple with a text editor and found that they had extra carriage return / line feeds between each line. I deleted the extras and now the patches will load.
Thanks Dave for posting these CHROMA templates! They are very good example of a different hardware synth architecture. People unfamiliar with the CHROMA can "get a look under the hood". Even if the patches are not used directly, the templates may be used as inspiration for new unique modular patches.
I've also enjoyed many of the other patches that you have posted for both the G1 and the G2. Keep up the good work!
varice
davep
Audio files: 10
G2 patch files: 73
PostPosted: Wed Sep 16, 2009 8:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
OK, reviving an old NM1 thread in response to some discussion about these patches in a different thread - I THINK I have replaced the corrupted patches with good files. And I'm adding one more:
Chroma Mode1Swell.pch
 Filename:  Chroma Mode1Swell.pch
 Filesize:  3.63 KB
 Downloaded:  68 Time(s)
Dave Peck
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Wed Sep 16, 2009 9:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Dave,
Are these rthe dame Patches as in http://nm-archives.electro-music.com/010_NordModular/011_Patches/Peck_David/ChromaPolaris/
or are these also corrupt... Shocked
Corruption could be the result of the server crash about a year or so back. Mad
Wout
davep
Audio files: 10
G2 patch files: 73
PostPosted: Wed Sep 16, 2009 9:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Wout!
It looks like they are the same patches in that location, maybe one exception. But I just checked several of them in that location and they all download & open OK, no need to replace them.
...Not sure why it says "Polaris" in that location, these templates are based on the big Chroma, not the Polaris. But a minor detail.
Dave Peck
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Wed Sep 16, 2009 11:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
davep wrote:
... But a minor detail.
Which I will take care of in a, hopefully soon, next update.
Wout
Niio1
