 Forum index » Instruments and Equipment » MAX/MSP - Pd
Phase Meter
Page 1 of 1 [5 Posts]
fabiopertile
PostPosted: Thu Jan 21, 2010 4:08 am    Post subject: Phase Meter
Subject description: Max/MSP How to?
Anyone know how to build a phase meter?
Scope does this very nicely in a visual form, but what I'm after is the ability to stream data expressing the phase (0-180 degrees) between left and right of a signal.. Any help would be awesome..
thanks
EdisonRex
Audio files: 168
PostPosted: Thu Jan 21, 2010 5:56 am    Post subject: Reply with quote  Mark this post and the followings unread
You might try reading this nasa paper for some ideas.
There are a couple of ways to go about it, but the problem gets tougher when you aren't dealing with two static frequencies.
It certainly will involve FFT of the two signals, although there are varying techniques for deriving differential phase information.
Seems like an interesting problem to solve.
Garret: It's so retro.
fabiopertile
PostPosted: Thu Jan 21, 2010 6:08 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks EdisonRex,
Yes, ffft will certainly be involved.
I had a quick skim over the paper. Very interesting stuff.
Wouldn't it be great if scope had output data to work with?
EdisonRex
Audio files: 168
PostPosted: Thu Jan 21, 2010 6:12 am    Post subject: Reply with quote  Mark this post and the followings unread
yeah, wouldn't that be nice. Either as two streams of pulses, a single PWM stream representing the difference in phase at zero crossing, or just numbers. Ah well. You know they're doing some of this stuff in Scope just to render the scope trace.
fabiopertile
PostPosted: Fri Jan 22, 2010 1:58 am    Post subject: Reply with quote  Mark this post and the followings unread
I was sent this in another forum.
Perhaps a good start.
It does measure and display difference from 0 degrees (mono)
But, when you feed perfectly out of phase audio it expresses only in the + range.
----------begin_max5_patcher----------
1452.3oc4Z1sbiZCE.9Z6mBMz613jQBL3P6z2fc5E8hdSZZFAHaqcAIJH6jr
6r9Yu5GvFrArbhSpyrWD.qeOmOczQRGkuOdjSD+IRoC3WA2AFM56iGMRmjJg
QU+djSF9o3TbotXNrUYQjhMNSL4kiEwKorEOTPhEl1AcK7F3D.JT+JLP8zEc
CDbeUcJoKTkTksIAZhto4Qe45ff5VdNmIJoeinxB4tsrY7DcRtU+VJOTVJQT
tWh7Uh8S0jj34bhQPUBBCm5LA3LOkikh+8M5aFNSWNm+hTjfYXGUV+X7X0iI
VBqXdVFgIpUIA4IMib9LeAM9ZR4+BxWhKIfXdQAIEKnbFHiHHECf2PeMPmYd
gNDuMoo+QnYK5g5jdvyLSXjGkh1AHIGj+vwTcDrok0LuAUcuWupi5yvwFykl
pgTqL.ohHxpPSIqIEkxQ7F8zHmcJqanR8BzOcglg4fY6TVImWjxi+JIownzH
mDx7SoM34D1txq4ZqGsKIkkWPJkVzZS086W7pTwCcS614OGGS5sx8.xQNKJn
IblRLZUWUx0c3c.8rB+lxsNeFNuipJ37zHbwZZIMJkzZbPZCiYzLrfHnF4wE
tsdzr7BJSzpsHLrrMVVFWvSSa0TlbV2QNIj0zXxizDwxVND2ysbC6lVytZk9
PyxZOS6SfqQ2zLmtloo4HZp90T39Sz1exl+sMaudLA5yac+S7rYx2v9lFU6e
x7wjyOMuBXKLMdr8lcTXN6mVXVfyxKy3bwxMRpAg5GVQ2aMLNH3Xz06EYp58
xna0FLtTvqxMX4RtXiZkT6LZqdAcOFWQA+zZ0hiJ2XEM8MtSQGkk9uDVh93X
ipEZ6L.Mayc6y9PV.xoOt.Oebod+7pd8bxCSmaEPbQPKIhqyoao.OAkc2VrR
or91shVOT42MEJ4qJhqIds6YPacJgTJnrs637tc9a1qfKoIIs2gmFzzjbtb2
ZUBH3dqF2NU412V4Vs59Ejbqb0Xkb2w.y+qxcfs79xRtU9ory91+xx9dlkxs
xsyYStqRTp.UQNBulj7frajNEe.KDEznUBiqmVGttqyX12ASkGhNBmVcL8sK
54b9N25fY12wlGuiDmoXNcMfxVSJDfbdJtfJdFvmC3LBHdIlwHo+M6Z.NIAH
3KHBIJT+lNGDI2LdcQJA3BBfJGLEzXb5Dfrb.4pG4qDfGooofHB.paG1y.0g
aMQzZdAOSZR76UA6JgNeNofvjrrRFU1gw7Ul0ZlNP7eBq1MpdIPOW8FoB76I
.PvKuXe0+XCZfvdMyrhum47itCE0K+fymR2LTOsBBmNbRd9gcEmn2bTc0fnx
CdBrx+iiAx+LTTQCq1Qn4EbPc16xSmyHkk3EjCzYU35l.R47bofL3ndkCAip
WcVUTX2DvCcJDv8zhK74+FD5IZ4kyySwOuA3dbp3WQkAun.2vWOU7N90rr6q
HLagcAPWsleUC8K+gtQL5t5S4etRcyEFFnbCYRw42bL6a3TsCkqCSKSkKuYw
cP3VETTHxDljtwJpNXSNQKh4o7hp1PWmsOZ59jWP6H751LsrdPwnA82aME0C
MfmnMhOeFpWswh6ywDWj.2a762BE8VNucuy5+VO68Sa.Wag+Ljwg1T+gl4hf
e.4ReKy8mCAE+lA5MbHlD9wYg8OOzM8BsUgmc4ovjukfiGZxe8M0UafOsm8w
ucINKLjgu.AMGKOYi0N7qmZ1y.wzs6+tPddljV2M61+0EPm9nRDN9qKzMYyx
tn.mfpu41aadysMEOUobqKEZZHzcRGenqwa.9bOI7M6sAe8bTlolixLMvqyi
xXAzGFmcM.X5CuPWTvDyn19jWWu1wT0LPreLapFNNL1XshwTewooU.zNLFMc
GelCLNNuxj26pLsW20Sb3t8cUlTaDGfNlLgZUn2EY5nbB9txIOarm1Sveysw
g1vIzqPlj+3Gi+OvEnya0
-----------end_max5_patcher-----------
AmbiphonicDSP
