j.dilisio
Posted: Sun Feb 21, 2010 12:38 pm Post subject:
Range Voltage Calibration/ Crap just crossed ground with +V Subject description: Now its acting funny |
Hello,. I just finished my Klee today and all functions seem to work as they should.
The one thing that is giving me trouble is the Range calibration. The values I'm getting with my meter are way off the mark.
1> -.333
2> -.013
3> -3.14
4> -3.32
5> -3.20
6> -.7
7> -.36
8> -.38
I was just wondering if anyone has had a similar problem or has a good guess at what might be the culprit.
I'm stumped at the moment.
Thanks,
J
EDIT: The one other thing I noticed as possibly not being normal was when I was checking the analog board IC ground pins. They weren't passing the continuity check until I soldered in the W1 jumper.
Is that normal? _________________ DRONEGOAT Last edited by j.dilisio on Wed Feb 24, 2010 2:15 pm; edited 1 time in total |
EdisonRex
Joined: Mar 07, 2007 Posts: 4448 Location: London, UK
Audio files: 168
Posted: Mon Feb 22, 2010 2:11 pm Post subject:
Reference voltage should be 10.0 at pin 3 of U5. That is a 7810, right?
The pot are simply acting as voltage dividers. There's not much else can be wrong there unless your analog ground isn't really at 0. Which, by the way, you were mentioning about the W1 jumper... Yes, unless you have tied grounds elsewhere, it should be jumpered. I expect that if you tie the analog ground down right, the numbers will drop more into place. _________________ Garret: It's so retro.
j.dilisio
j.dilisio
Posted: Tue Feb 23, 2010 6:30 pm Post subject:
Ok,. all fixed.
Steps 2-8 of the range switch were wired backwards.
I'm still getting negative voltages at pin1 of U8 but the pitch intervals sound correct.
Thanks. _________________ DRONEGOAT |
EdisonRex
Audio files: 168
Posted: Wed Feb 24, 2010 3:55 am Post subject:
Have you set the register offset trimmers R42 and R43 yet? You want to get those to zero. If you've been in rewiring and haven't recalibrated you might want to go back and do that again. It doesn't eliminate 100% of offsets but it'll help. Also very good that you're getting scaling, it does just sound like a trim problem. Does the B side have the same problem? R43, U9 pin 1 _________________ Garret: It's so retro.
j.dilisio
Posted: Wed Feb 24, 2010 9:45 am Post subject:
Sorry,., what I meant to say is that it's functioning correctly ie correct intervals and no audible offset. The voltages are correct as well,. just on the negative side.
-8, -4, -2, -1, -.666 ...
I do get an almost identical set of voltages at pin1 of U6 (MaxV in the schematic), except that they're positive.
It works, I'm happy.
Thanks again. _________________ DRONEGOAT |
j.dilisio
Posted: Wed Feb 24, 2010 2:31 pm Post subject:
This is frustrating. I just crossed the ground connection with +15V at the power supply by accident. Now I'm getting some strange behavior.
1- The clock is affecting the pitch of the VCO thats attached.
This also occurs with the power off.
EDIT: This is also true of the random and load inputs.
2- Although the range callibration still measures correctly, the pitch intervals are all considerably less than they should be.
3- When the sliders of steps who's voltages are being combined are too high, the clock stops.
It was working fine before so I'm guessing I've got a blown part or two somewhere.
Any guesses/ advice? _________________ DRONEGOAT |
j.dilisio
Posted: Wed Feb 24, 2010 6:47 pm Post subject:
So in this situation would it be best to order replacements for all of the ICs and transistors and switch them out one at a time?
I don't really understand whats going on in most of the circuit to pinpoint the problem. _________________ DRONEGOAT |
j.dilisio
Posted: Sat Feb 27, 2010 8:05 pm Post subject:
I tried switching out all of the ICs to no avail.
Edit: I thought I was having a problem with the voltage outs but they measure fine. What does it mean if I'm getting the correct voltage output but the pitch intervals don't correspond? _________________ DRONEGOAT |
j.dilisio
Posted: Sun Feb 28, 2010 10:32 am Post subject:
I just hooked up my scope to ground to do a little probing and the Klee magically resurrected itself so I believe the problem is with my power source.
All better. _________________ DRONEGOAT |
