Sub levels
Page 1 of 1 [3 Posts]
Perfect Day
PostPosted: Sat Jul 10, 2010 1:57 am    Post subject: Sub levels Reply with quote  Mark this post and the followings unread
Hi as some of you will be aware Ive been having problems with my sub osc levels , I still have them and would like to know if maybe your A6 does to , so Ive uploaded a sysex program file you can load into your machines if you dont mind and let me know if your sub levels are inconsistant with the patch Ive created . All you need to do is press a key 16 times . If yours are the same you will clearly hear the sound change somewhere between the 16 voices . the sub you will hear is of osc 1 only although the level is set of the other sub you will need to turn down osc 1 main volume , and then turn up osc 2 to test the other sub on its own . The file came from program bank user 00 originaly . Any comments even if the levels are fine would be greatly appreciated Smile Thanks
sub osc prob.syx
Bad levels
 Filename:  sub osc prob.syx
 Filesize:  2.29 KB
 Downloaded:  62 Time(s)
Shreddie
PostPosted: Wed Jul 14, 2010 2:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've not downloaded your patch as I'm sure I would've noticed any differences in my levels. I have had a thought though...
Have you calibrated your VCA's? It's not part of the autotune routine on the A6 and has to be done manually. To do it, press autotune once then soft button 3 (I think) twice. Calibrating the VCA's should get the levels equal in theory.
Perfect Day
PostPosted: Thu Jul 15, 2010 12:13 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the reply . Tried it however . Tried everything I can think of . reinstalling os all the power up modes etc . THe only thing left to do is see if other users experience the same thing . You may not of necissarilly noticed it . The levels have to be near 3 and the voices rotary . even if you use noises with long release in poly mode you may not notice it , the subs level off at around 10 , It would be good if you could install the patch just to make sure Smile
