<on air> bingsatellites Mostly Ambient
 Forum index » Instruments and Equipment » Chameleon
note generation using audio in
Page 1 of 1 [7 Posts]
s1m0ne
PostPosted: Tue Jun 22, 2010 12:40 pm    Post subject: note generation using audio in Reply with quote  Mark this post and the followings unread
hi all, here's the result of my work on the machine so far, the idea was to generate a note using the audio input:
- first you hear a (very) short snippet of music (tortoise - standards)
- then you hear the dsp generating two notes (first an A than a G) using the acquired samples
A few results are presented in sequence... thanks for listening !
Simone
chameleon_vs_tortoise.mp3
 Filename:  chameleon_vs_tortoise.mp3
 Filesize:  6.42 MB
 Downloaded:  140 Time(s)
DrJustice
PostPosted: Tue Jun 22, 2010 7:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Simone!
welcome to electro-music.com Very Happy
It's an interesting sound you've got there. Unfortunately I don't understand fully what's going on except that a sound is captured and then transformed and played back in some way. I'd love to hear more about what the process is.
DJ
s1m0ne
PostPosted: Wed Jun 23, 2010 12:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
You got it right, first the data coming for the audio in is stored in memory (and played back), then, when the 'buffer' is full, the acquired data is used to produce the A/G notes (the two long sounds that you hear after the short piece of music).
To generate the notes, the sampled data is 'sliced' into short sequences (whose lenght determines the note frequency) and each 'slice' is reproduced a given number of times; after that the next 'slice' is reproduced, and so on... until all the data in the buffer has been used.
I hope this clears things a little Smile
Simone
DrJustice
PostPosted: Wed Jun 23, 2010 12:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
OK, so it's a kind of granular pitch shifting/synthesis algorithm then. It's cool to hear people using the Chami for experiments thumleft
Do you plan to develop any full soundskins for it?
DJ
s1m0ne
PostPosted: Thu Jun 24, 2010 2:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Update: you can connect a midi keyboard to play different notes, on a four octaves range.
Here's the result, thanks for listening !
Simone
chameleon_audio_in_midi.mp3
 Filename:  chameleon_audio_in_midi.mp3
 Filesize:  5 MB
 Downloaded:  138 Time(s)
s1m0ne
PostPosted: Mon Jun 28, 2010 12:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
Another update, I added a midi control for portamento and to define the numbers of iterations for each 'slice'.
Also, I implemented an 'audio in monitor' function, so that it's possible to monitor the audio in, and decide when to 'sample'.
Short audio file attached.
Simone
chameleon_audio_in_controls.mp3
 Filename:  chameleon_audio_in_controls.mp3
 Filesize:  1.28 MB
 Downloaded:  129 Time(s)
vexkon
PostPosted: Tue Nov 09, 2010 7:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Is this going to be a skin? Thanks for doing this. love the grains Smile
