ChucK, effects and looping samples
Page 1 of 1 [3 Posts]
circuitbent
PostPosted: Sun Oct 31, 2010 2:47 pm    Post subject: ChucK, effects and looping samples
Subject description: [UPDATED]
Ok, so here it the scoop. I'm trying to create a chuck program that controls effects on loops in realtime through OSC. Problem I am facing is with trying to use delay. I want to be able to set the delay in real time, much like a delay pedal/effect unit. Problem is, when I try to use:
Code:
delayTime::ms => delay.max => delay.delay;
from the Echo Example, this seem to reset any of the delay built up.
Any advice?
circuitbent
PostPosted: Sun Oct 31, 2010 3:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ok. I think I got it.
I guess when you change delay.max, it resets the delay, but if I just set delay.delay I can change it on the fly.
GrandJu
PostPosted: Mon Nov 01, 2010 3:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Delay.max is to be set one time. It represant the maximum delay your program will use.
I'm not sure but I think Chuck use this function for memory allocation of the delay line.
Have fun!
Ju
Niio1
