delayed
Posted: Wed Jul 21, 2010 11:48 pm Post subject:
Tempco Resistor Question |
Will this part below work to replace the PT094 2K tempco in the MFOS VCO or other projects that require a tempco resistor?
This is a 1K so would two work out?
Thanks,
1k PTC from mouser LT1/4LT52R102J3900
http://www.mouser.com/ProductDetail/KOA-Speer/LT1-4LT52R102J3900/?qs=bQqEcw2qv2QjD1HR3vMEzw%3d%3d
Mouser Part #: 660-LT1/4LT52R102J39
Manufacturer Part #: LT1/4LT52R102J3900
Manufacturer: KOA Speer
Description: Thermistors - PTC 1K OHM 5% |
magman
Joined: Feb 04, 2009 Posts: 351 Location: Liverpool, UK
Posted: Thu Jul 22, 2010 3:39 am Post subject:
A pair of these resistors in series would be better than a 2K Metal Film resistor, the only note being that these appear to be 3900ppm, rather than the 3500ppm specified.
An alternate source of 2k 3500ppm tempco's though is Magic Smoke. They have them listed on their website here:
http://www.magsmoke.com/tempco-resistors.asp
But there was also a recent thread in the Thomas Henry Designs sub forum where Tim Servo advised that they are now available at about half these prices:
http://electro-music.com/forum/topic-19122-125.html (scroll towards the bottom of these posts)
Good hunting.
Regards
Magman |
delayed
Posted: Thu Jul 22, 2010 8:18 am Post subject:
Thank you for the reply and the link.
What does the "3900ppm, rather than the 3500ppm specified" number mean? Or how would it change the circuit? I have not ever used one of these and don't know the difference.
Thanks again, |
magman
Posted: Thu Jul 22, 2010 8:55 am Post subject:
I think the ppm is parts per million and is the degree of temperature change per degree Celsius.
In other words, for a 3500ppm part, the resistance will change by 0.35% per degree C change in temperature.
With normal resistors you want a small temperature drift (normally less than 200ppm), but the tempco is used to adjust a value to keep an oscillators frequency constant as the temperature changes (such as on stage or even as the temperature changes in your house), so you want a much bigger change in resistance per degree C change.
Here's a useful link from Elby Designs which explains how they adjust a 3500ppm tempco to fit a 3300ppm requirement for an ASM1/2 oscillator:
http://www.elby-designs.com/datasheets/tempco.pdf
The 3900ppm part you originally linked to would probably have to have a similar adjustment process to work in the MFOS application as designed.
Hope that helps.
Magman |
delayed
Posted: Thu Jul 22, 2010 9:03 am Post subject:
| That helps a lot. Thank you for explaining that. |
Tim Servo
Joined: Jul 16, 2006 Posts: 903 Location: Silicon Valley
Posted: Thu Jul 22, 2010 12:34 pm Post subject:
We have those in stock, and yes, we have them from a new supplier at a lower price.
1 for $1.80, 2 to 5 for $1.50 ea, 6 or more $1.20 ea
shipping = $1.50 US/Canada, $3.50 EU/UK/Aus
Tim (shipping stuff this weekend) Servo |
inlifeindeath
Joined: Apr 02, 2010 Posts: 286 Location: Albuquerque, NM
Posted: Sun Jul 25, 2010 12:50 pm Post subject:
| what is your company name and how can i buy these through mailorder? Thanks |
Scott Stites
Joined: Dec 23, 2005 Posts: 4119 Location: Mount Hope, KS USA
Audio files: 96
Tim Servo
Posted: Sun Jul 25, 2010 6:11 pm Post subject:
Whoops, thanks for helping with that Scott. I made the mistake of assuming that inlife already knew about Magic Smoke. My bad.
You can go to www.magsmoke.com and look around, or just send us an email to magsmoke@gmail.com and I'll send you a copy of the latest price list. For payment, we take PayPal to magsmoke@gmail.com
Tim (packing and shipping) Servo |
RobotDad
frijitz
Audio files: 54
Posted: Mon Aug 30, 2010 8:03 pm Post subject:
That's the wrong kind of thermistor. Notice it says NTC. That's Negative Temperature Coefficient. What we use is a PTC. If you look up the specs for the correct type of device, the manufacturer will specify the temperature coefficient in ppm/deg.
Ian |
RobotDad
Posted: Mon Aug 30, 2010 9:31 pm Post subject:
Ah, thanks. Looking up the right type of part seems key.  |
frijitz
Audio files: 54
Posted: Tue Aug 31, 2010 4:16 am Post subject:
| TechDiplomat wrote: | Ah, thanks. Looking up the right type of part seems key.  |
No need to . It's quite confusing. The key is that "thermistor" is a very general term that covers several types of devices that work very differently.
Ian |
darkomen
Posted: Tue Nov 16, 2010 4:36 pm Post subject:
Going off of the link that magman posted, I just want to run this by to see if I did the math correctly.
If I take the 1k ohm 3900 ppm/C resistor and run it in series with a 340R resistor that's 100 ppm/C (both at 25 degress C), that would give me 3347.8 ppm/C, correct?
Also, if I wanted a 2K ohm tempco resistor and took 2 of the 1K in series would the 340 ohm resistor still be sufficient or do I need to recalculate? |
frijitz
Audio files: 54
Posted: Tue Nov 16, 2010 6:08 pm Post subject:
| darkomen wrote: | Going off of the link that magman posted, I just want to run this by to see if I did the math correctly.
From the formula I get 170R for the 1k tempco and 340R for the 2k tempco.
But please remember that the uncertainty in the temperature coefficient can be up to 15%. So a 3900ppm tempco could actually be anywhere between 3315ppm and 4485ppm.
A device from a batch of the old 2k Q81 3900ppm units that I checked out needed ~170R for the series correction resistor. I got this by trying different values until I got good compensation in a VCO. So don't take the numbers from the formula too seriously.
Ian |
darkomen
Posted: Wed Nov 17, 2010 12:18 pm Post subject:
Thanks for checking this for me (I realize that I actually calculated it for the 2k not the 1k, thus getting the 340 and not the 170 in my post). And thanks for the info, guess I'm better off just buying tempcos at 3500 ppm/C instead of fudging it.
Also you mentioned that you had some tempcos that you were trying to compensate for, how did you go about testing them to find the ideal resistor for compensating the tempco. Did you heat them for a little and check the drift on the resistance? |
frijitz
Audio files: 54
Posted: Wed Nov 17, 2010 2:02 pm Post subject:
| darkomen wrote: | | Also you mentioned that you had some tempcos that you were trying to compensate for, how did you go about testing them to find the ideal resistor for compensating the tempco. Did you heat them for a little and check the drift on the resistance? |
Right. I used a setup similar to this:
http://home.comcast.net/~ijfritz/sy_cir9.htm
Ian |
adambee7
Joined: Apr 04, 2009 Posts: 420 Location: united kingdom
Posted: Fri Nov 26, 2010 3:08 am Post subject:
Thanks Ian for the article. that has taught me more about temps than a book ever could. Would a heating pad used to heat tanks for reptiles be good enough?  |
frijitz
Audio files: 54
Posted: Fri Nov 26, 2010 4:40 pm Post subject:
| adambee7 wrote: | Would a heating pad used to heat tanks for reptiles be good enough?  |
Probably, although I'm not that familiar with them. With some insulation wrapped around everything it will probably get plenty warm, but I'm not sure how much time it will take.
Ian |
adambee7
Posted: Sat Nov 27, 2010 1:53 am Post subject:
| frijitz wrote: | | adambee7 wrote: | Would a heating pad used to heat tanks for reptiles be good enough?  |
Ian |
I'll do a little experiment with it over the weekend. cheers Ian. . |
