  Twyndyllyngs Live from Howard's! Chez Mosc
FUSE-Bits ATTiny2313
Boerge
PostPosted: Tue Apr 12, 2011 12:16 am    Post subject: FUSE-Bits ATTiny2313 Reply with quote  Mark this post and the followings unread
I have a little Problem with this MIDI2CV-circuit:
http://www.analog-synth.de/avr/midicv.htm
I set the FUSE-bits like this:
CKSEL for external crystal 3-8MHz => CKSEL=1100
Startup time short => SUT=00
Clock output on port D2 => CKOUT=0
but it doesn't work. On the clock output I see the 4MHz clock on my scope. The sourcecode says " ProcClock = 4000000; { Hertz }", so I think the CLKDIV must not be set. The CV output changes when i play some keys, but not reproduceable. It seems likte the ATTiny doesn't always 'understand' the MIDI signals, although the input after the CNY17 looks good. What FUSE-bit setting would you recommend?
thanky in advance
Boerge
...ich will doch nur löten...
