Stripboard Layout for Moog Rogues VCO
Page 1 of 1 [2 Posts]
Juno60
PostPosted: Thu Jul 22, 2010 3:32 am    Post subject: Stripboard Layout for Moog Rogues VCO Reply with quote  Mark this post and the followings unread
Hey @ all!
I finished my stripboard layout for the Moog Rogue VCOs. For lack of time, it's not tested yet. Maybe someone of you want to test it. Wink
All parts used are from the original schematic and should be available today. The two resistors laid over the CA3046 are 1W 100Ohms tempcos.
The schematic can be found on the web for troubleshooting.
Cheers, Chris
 Filesize:  163.37 KB
 Viewed:  308 Time(s)
 Filesize:  192.63 KB
 Viewed:  152 Time(s)
 Filesize:  152 KB
 Viewed:  212 Time(s)
 Filesize:  188.17 KB
 Viewed:  155 Time(s)
Greetings from Germany,
Chris
citric acid
PostPosted: Sun Oct 16, 2011 3:03 am    Post subject: Reply with quote  Mark this post and the followings unread
hi chris,
have you tested /build this ? does it work ?
liebe grüße,
cit
http://soundcloud.com/citric-acid-303
