  bingsatellites Mostly Ambient
Recorder Advise
Page 1 of 1 [6 Posts]
BobTheDog
PostPosted: Thu Apr 14, 2011 11:24 am    Post subject: Recorder Advise Reply with quote  Mark this post and the followings unread
I still have not purchased a portable recorder and am thinking of it again!
I was thinking of the Sony PCM-D10 or the Olympus LS-11.
Anybody got one of these and what are they like?
Also any other devices I should look at?
Thanks for any help
Andy
Muied Lumens
Audio files: 204
PostPosted: Thu Apr 14, 2011 11:58 am    Post subject: Reply with quote  Mark this post and the followings unread
I have the Olympus LS-10 and can recommend it for general recording. Most of my files in this forum has been recorded with it. One area where it does not excel is with quiet sounds, you start hearing the peramp hiss then, but otherwise it is a good sounding recorder if you don't need phantom power. I am pretty sure (although not 100%) that the LS-11 uses the same preamps. Oh, and the battery time is amazing on the LS10!
The Sony will probably be quieter, although I would definitely want to try it out before buying. It looks like it is smaller and much easier to handle than the Olympus. I don't know much about it though.
If you want an other alternative, try one of the Tascams, they have sounded good to my ears in the past.
Muied Lumens Base Star
Muied Lumens
Audio files: 204
PostPosted: Thu Apr 14, 2011 12:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Reading up a little on the Sony, it looks like a good recorder - but most of all, the 5 second pre-recording buffer could be very useful for me! Saves you a lot of editing if you are sitting there waiting for a special sound to appear. Of course, the track marker does a similar job - IIRC the LS-11 has track marker facilities. And enough memory.
BobTheDog
PostPosted: Thu Apr 14, 2011 11:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Rob,
Thanks for the info.
I'm up in London at the weekend and will see if there are any music shops still around and have a listen if possible.
Andy
Audio files: 116
G2 patch files: 317
PostPosted: Fri Apr 15, 2011 1:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sony, right - better read the specs a couple of times & check the internets .. they bit me once a looong time ago with some foolish DRM scheme; that was my last Sony.
BobTheDog
PostPosted: Fri Apr 15, 2011 1:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wasn't that Rootkit fiasco was it?
