drone machine with adapted soundlab circuits
Page 1 of 1 [4 Posts]
synthesist
PostPosted: Mon Jul 18, 2011 11:57 pm    Post subject: drone machine with adapted soundlab circuits Reply with quote  Mark this post and the followings unread
I'm building a cmos based drone machine with an adapted version of the soundlab mini synth filter.
It's basically 2 Oscillators with Pulsewidh control and 1 LFO + pseudo Attack-Release Envelope control build with a CD40106 chip. Nothing fancy so far.
But since I figured out, that it's easy to drive the SL-minisynth filter with only a single 9-volt batterie by building a virtuell ground, I had to include an adapted circuit.
It sounds DOPE now!! Fat bass and chorus like sounds + a sine-like wave when the resonance pot is turned all the way clockwards. The filter is gated by the AR-LFO from the CD40106 and sounds even better than the one from my original soundlab.
The next step would be to include the white noise source from the SL-minisynth.
But first I need some help:
My volume pot sounds grinding while I am turning it. But when the volume is fixed it's gone. Only while I am turning it it makes this noise. Also when I twist the switch, which selects between BP and LP Filter output. Though I think the switch shorts BP and LP and this could be the problem.
I didnt use a decoupling capacitor on the output of the circuit, because it seems that it would filter the sound again. No matter which value I tried.
May this be the problem?
inlifeindeath
PostPosted: Tue Jul 19, 2011 5:55 am    Post subject: Reply with quote  Mark this post and the followings unread
sounds like you have DC across the pot
synthesist
PostPosted: Tue Jul 19, 2011 9:44 am    Post subject: Reply with quote  Mark this post and the followings unread
DC across the volume pot. hmh.....that's not good.
So a nonpolarized capacitor should help. But it filters the output signal with every value that I tried so far.
I'm gonna make some trial 'n' error before I break my head.
thanks
I'll let you know if I figure out something new.
synthesist
PostPosted: Tue Jul 19, 2011 12:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
yes! I got it.
The capacitor value that I tried to use for decoupling was actually o.k.
It wasnt filtering the output sound, but the sound gets distorted easier. So I needed a 47k resistor. Now the capacitors dont affect the output anymore and the volume pot doesnt grind anymore.
Niio1
