  bingsatellites Mostly Ambient
Living VCO dies...sort of
Page 1 of 1 [5 Posts]
numbernone
PostPosted: Fri Aug 19, 2011 9:46 am    Post subject: Living VCO dies...sort of Reply with quote  Mark this post and the followings unread
Have had the VCOs humming nicely since last December. About 2 weeks back the center OSC begins to experience what I would call voltage burps here and there, fluctuations sometimes small sometimes large in the pitch. Yesterday it seems to have stabilised. After about 3 hours the center OSC has dropped out and is producing a profound hissy noise only, most powerful from the square output with the PWM CCW.
I am prepared to dig in for the fix, however my wiring is tight and I want to target potential problem zones first, and this is the strangest VCO problem I have ever had.
All help appreciated in advance. Important gig next week and I want a full trio of power filling the night skies of West Virginia!
numbernone
PostPosted: Fri Aug 19, 2011 10:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Redacted update...user error
Checking it now, there is some pitch present in all the noise. However even at its maximum CCW setting, the pitch is very high and and increases in pitch and fades the volume out in about 3 full turns CW.
numbernone
PostPosted: Sun Aug 21, 2011 3:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
Having returned after a day off. I have observed its behaviour (at the ear only) from a cold start.
The noise is now very gritty with a digital arcade timbre, given 5 minutes or so this smoothes into whitish noise. There is hi frequency oscillation present, which responds to all controls but to a MUCH greater magnitude. Even the linear detune knob would easily cause more than an "octave" in variation, while the tune pot goes well beyond audible to silence in about 3 full turns. The manual PW sounds like a hi pass filter, cancelling the signal at approx 50% rotation CW.
I have swapped the easy chips to no effect, voltages at pots are right. Will try the 3046 next just to rule out ICs.
Funny part is this is most definitely the most lively noise generator I have ever dealt with. I almost wish I didnt have to fix it.
jhaible
PostPosted: Tue Aug 23, 2011 12:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
Brian Eno probably wouldn't fix it. Smile
Seriously: This sounds like a cold solder joint or some such. Something making contact sometimes, and loosing contact sometimes, and then picking up something on the disconnected, high impedance node ...
JH.
numbernone
PostPosted: Tue Aug 23, 2011 2:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
I have decided to hold off til after the big gig weekend. It has a flavor I might be able to use.
Eno lover here.
