 Forum index » Wanted, For Sale, Opportunites and Requests » Equipment/Software Wanted and For Sale
FA: Moog CP-251
egw
G2 patch files: 8
PostPosted: Mon Nov 28, 2011 5:37 am    Post subject: FA: Moog CP-251
Subject description: control processor
My Moogerfooger CP-251 is up for auction on ebay:
http://www.ebay.com/itm/320802797888?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
Excellent condition, works perfectly. Manual and power supply (120V) are included.
Features: FOUR INPUT MIXER - Enables you to combine control signals to create complex effects. LAG PROCESSOR - Reshapes control signals by slowing down abrupt changes, used to produce glides and swoops. LOW FREQUENCY OSCILLATOR (LFO) - Makes periodic control signals over the range of one cycle every five seconds to 50 cycles per second. The LFO is itself voltage-controlled so you can vary its rate with an expression pedal or other control signal to create effects such as vibrato, warbles, and sirens. Two ATTENUATORS - To reduce the strength of control signals, enabling you to adjust the strength of an effect. FOUR-WAY MULTIPLE - Enables you to send one control signal to as many as three destinations. NOISE SOURCE - Provides pure noise for use as an audio or control signal. SAMPLE AND HOLD - Produces stepwise control signals by sampling the voltage of any signal at rate of the LFO to produce classic sample-and-hold effects. This circuit also has a second output which is a smoothed version of the stepwise output.
 Filesize:  139.4 KB
 Viewed:  36 Time(s)
www.gregwaltzer.com
