FaschingsPrinz
G2 patch files: 4
Posted: Mon Dec 05, 2011 11:54 pm Post subject:
MIDI-Transfer between Slots Subject description: How to transfer MIDI-commands between slots ? |
Hello friends,
I found in the manual, that it is possible to transfer MIDI-commands between slots. But I was not able to accomplish that.
If I have a MIDI-Note-send module in SlotA, how can I transfer this MIDI-Commands to another slot ? I would like to use the notes generateb by a self-made arpeggiator in several slots but don´t know how.
Usualy I would use the regular busses to transfer the cv, but because I only use all busses and fx-busses to transfer other signals, I ran out of transfer-options.
I can choose "SLOT B" as destination on the send-module, but what do I have to use in slot B to receive it there ?
On the receive-modules I only have the choice between channel 1-16, this and keyboard.
And further more, there is no note-output, but just the trigger- and velocity-outs.
Thanx for your help,
FaschingsPrinz _________________ "If I have an apple, and you have an apple, and we exchange apples, then you and I still have ONE apple.
But if I have an idea, and you have an idea, and we exchange ideas, then we BOTH have TWO ideas."
G.B.SHAW |
Estarriol
Posted: Tue Dec 06, 2011 12:07 am Post subject:
| I think this note sending to another slot has no difference than playing a keyboard for that slot, so KBD or MONO modules should work. |
Audio files: 218
G2 patch files: 93
Posted: Tue Dec 06, 2011 12:36 am Post subject:
In slot B you use "this" is channel in the CtrlRcv module. This will receive data sent to SlotB from other slots. _________________ Antimon's Window
@soundcloud @Flattr @myspace A blog home - you can't explain music |
FaschingsPrinz
G2 patch files: 4
Posted: Tue Dec 06, 2011 12:41 am Post subject:
@Estarriol
The problem is, I do not "play" the notes on the keyboard but generate cv for note, gate/trigger and velocity.
These notes (cv-values) are actually transfered via MIDI-OUT to MIDI-expanders.
But I would like to further process these cv-data in other slots, but don´t know how to send it there.
A work-around is to connect the MIDI out (hardwarer) to a MIDI-splitter (hardware; by midi-solutions) and send it from there to the expander and use the copy of the signal (done by the splitter) and route it with a MIDI-cable back to the MIDI-IN of the G2; I use this for simultanious movement of encoders without having to use morphes, because the value shown on the front are actual values and no cryptic -64 to +64. _________________ "If I have an apple, and you have an apple, and we exchange apples, then you and I still have ONE apple.
G.B.SHAW |
FaschingsPrinz
G2 patch files: 4
Posted: Tue Dec 06, 2011 12:45 am Post subject:
so you mean, I should use the CtrlRcv-module instead of the NoteRecv-module and assign a not used controller-number to that, and use a separate module for gate/trigger, velocity and note-number ?
I never thought about that !
Thanx a lot !! _________________ "If I have an apple, and you have an apple, and we exchange apples, then you and I still have ONE apple.
G.B.SHAW |
ian-s
Joined: Apr 01, 2004 Posts: 2519 Location: Auckland, New Zealand
Audio files: 42
G2 patch files: 584
Posted: Tue Dec 06, 2011 1:28 am Post subject:
Re: MIDI-Transfer between Slots Subject description: How to transfer MIDI-commands between slots ? |
| FaschingsPrinz wrote: | | I can choose "SLOT B" as destination on the send-module, but what do I have to use in slot B to receive it there ? |
You can use the KBD module from the in/out group. It will give you note,gate and velocity from the note send in slot A. |
Audio files: 218
G2 patch files: 93
Posted: Tue Dec 06, 2011 2:59 am Post subject:
Sorry I missed that you were using NoteSend and NoteRcv. The same principle should apply there, if you set the NoteSend to channel=SlotB, and NoteRcv (in slot B) to this, that should work too.
Estarriol
Posted: Tue Dec 06, 2011 11:28 am Post subject:
| Guys if topic author wants to send different notes to slotB, NOTERCV module may not work, it's made to capture ONE note (E4, C3 etc) AFAIR. |
Audio files: 218
G2 patch files: 93
Audio files: 218
G2 patch files: 93
Posted: Tue Dec 06, 2011 2:58 pm Post subject:
FaschingsPrinz: Oh I realize you may want to send multiple note ons to the same slot... Yeah that's tricky - your description of how you'd use the CC modules might work for that. _________________ Antimon's Window
varice
Joined: Dec 29, 2004 Posts: 628 Location: Northeastern shore of Toledo Bend
G2 patch files: 47
Posted: Tue Dec 06, 2011 4:37 pm Post subject:
| Antimon wrote: | | ...Won't simply the keyboard module (sixth icon under In/Out) work? |
The monokey and keyboard modules will work, but are not absolutely necessary to work with notesend modules, as you can build patches that work without the key modules (with Osc, Filter, and EG modules that have the “KBT” function).
Estarriol is correct, as long as a patch in a slot will respond to normal MIDI keyboard input, you do not need to do anything special to it for it to work with a NoteSend module from another slot.
A working example of how this is done is in my noodle perf “Fast Thinking”:
http://electro-music.com/forum/topic-5099.html
OT: That’s weird – Jan’s reply to that topic has disappeared  _________________ varice |
Joined: Apr 03, 2004 Posts: 19623 Location: The Netherlands, Enschede
Audio files: 116
G2 patch files: 317
Posted: Tue Dec 06, 2011 4:40 pm Post subject:
But I said something like that it is a nice patch and maybe that it was played on the noodle radio, and also that there is a recorded version of it on the forums that occasionally gets played on the radio here still.
Anyway .. no idea how that post got deleted. _________________ Jan |
varice
G2 patch files: 47
Posted: Tue Dec 06, 2011 5:58 pm Post subject:
Jan, if my memory serves me right, your reply was a statement that you liked “Fast Thinking” and considered it to be a *song* because it had a planned ending (as opposed to other noodles which normally continue to play as long as the patch/perf is loaded). Howard’s reply also reflects your comment about its ending. Still – weird about the disappearing reply. I’m sorry everyone (and especially FaschingsPrinz) for getting off topic about this. _________________ varice |
