My small Juno-106 repair thread
Page 1 of 2 [43 Posts]
my05
PostPosted: Sat Apr 03, 2010 3:39 am    Post subject: My small Juno-106 repair thread
Subject description: Some pictures and text around it
Hello forum,
This january, i purchased a top cover from LektroiD here on this forum (thanks again, mate) and promised him to publish some pictures from my restoration of a juno-106 (replacing faulty wave-chips, voice-chips and quite a lot of other stuff).
I will try to put images and text in this thread later today and hopefully it will help someone else doing what i did. I am i no way a soldering expert but taking it slowly and methodically (and having a small enough soldering-iron) will definately help.
Stay tuned.... Smile
Kind regards
Daniel
my05
PostPosted: Sun Apr 04, 2010 1:11 pm    Post subject: Opening her up and de-soldering voice chips, wave and 662 Reply with quote  Mark this post and the followings unread
Why did i undertake this operation to begin with? First of all, two of my voices did not work. The sub-osc did not work either, nor did the white noice. I got the juno off Ebay from a german seller and it had seen better days (to say the least). The top-cover was very rusty (not kidding) and most things were loose (bender board for example). I had one of these over 20 years ago which i bought almost new with its original casing, etc. When the D50 arrived i went digial all the way and sold it (which i have regretted since). I then found this and purchased it, not knowing exactly what i was in for..... Smile
The first thing i did was to extract the main board where the voice and wave chips are. There are 6 voice chips and 3 wave chips:
(Voice-W-Voice-Voice-W-Voice-Voice-W-Voice) counting the rightmost voice chip as number #1, etc (from right to left, 1 to 6)
Before the "surgery" begins :-)
 Filesize:  3.17 MB
 Viewed:  217 Time(s)
The lid is open....
 Filesize:  385.57 KB
 Viewed:  260 Time(s)
my05
PostPosted: Sun Apr 04, 2010 1:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
While disconnecting everything, it is very wise to also document where the wires and stuff go...
 Filesize:  278.22 KB
 Viewed:  199 Time(s)
 Filesize:  537.48 KB
 Viewed:  204 Time(s)
 Filesize:  3.46 MB
 Viewed:  192 Time(s)
 Filesize:  564.13 KB
 Viewed:  201 Time(s)
 Filesize:  460.09 KB
 Viewed:  209 Time(s)
my05
PostPosted: Sun Apr 04, 2010 1:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Time to desolder voice chips. Best thing is to have a small enough soldering iron and means to clean as much of the old solder as possible
 Filesize:  304.64 KB
 Viewed:  194 Time(s)
Try not to do what i did and burn yourself in the finger. It hurts..... ;-)
 Filesize:  183.66 KB
 Viewed:  167 Time(s)
my05
PostPosted: Sun Apr 04, 2010 1:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
old voice chip de-soldered and new one in place to be soldered on....
 Filesize:  330.7 KB
 Viewed:  190 Time(s)
my05
PostPosted: Sun Apr 04, 2010 1:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
After doing the same for the other voice chip and the faulty Wave-chip (which was the cause of the missing sub-osc) it was time to swap the old rusty cover for the new one that i purchased from LektroiD.
First pictures of how the old rustbucket looked like:
 Filesize:  77.81 KB
 Viewed:  199 Time(s)
 Filesize:  62.48 KB
 Viewed:  177 Time(s)
 Filesize:  84.43 KB
 Viewed:  180 Time(s)
 Filesize:  76.71 KB
 Viewed:  193 Time(s)
 Filesize:  86.79 KB
 Viewed:  186 Time(s)
my05
PostPosted: Sun Apr 04, 2010 1:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
To be continued tomorrow...
Audio files: 167
G2 patch files: 319
PostPosted: Sun Apr 04, 2010 1:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice thread Daniel!
my05
PostPosted: Sun Apr 04, 2010 3:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Jan,
I hope this might help someone else doing the same thing Smile
The wave chip is actually a clone from D'naab (tried Roland but original Wave chips seems to be extremely difficult to get hold of. As for the voice chips, Roland Sweden apparently found a full bucket of them (yes, no kidding) in a closet where they had been for many years unnoticed). Here is a closeup of the voice+wave soldered on:
 Filesize:  296.01 KB
 Viewed:  249 Time(s)
my05
PostPosted: Sun Apr 04, 2010 4:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
To swap the cover, you have to extract the jack board, midi board and control board + take out the power supply plug, etc. Did i mention that photo-documentation is key Smile
Also, in my case i found it impossible to get the power plug out so i cut the wires and re-soldered them when the new top-cover was in place again.
 Filesize:  278.02 KB
 Viewed:  204 Time(s)
midi-board
 Filesize:  129.22 KB
 Viewed:  194 Time(s)
The panel board when extracted from the top-cover
 Filesize:  267.09 KB
 Viewed:  200 Time(s)
The fuse board. Soon to be cut to get the power-plug out...
 Filesize:  145.96 KB
 Viewed:  190 Time(s)
my05
PostPosted: Sun Apr 04, 2010 4:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here, everything is lined up for soldering and assembly. Just reverse the procedure and be careful that you don't miss anything
 Filesize:  237.64 KB
 Viewed:  197 Time(s)
put the midi-board back in place again
 Filesize:  131.41 KB
 Viewed:  188 Time(s)
the pushbuttons (i swapped them over from my old panel-board)
 Filesize:  125.3 KB
 Viewed:  191 Time(s)
reconnect the plugs
 Filesize:  306.12 KB
 Viewed:  204 Time(s)
Solder back the power leads (be extremely careful not to swap the leads by mistake...)
 Filesize:  178.51 KB
 Viewed:  192 Time(s)
my05
PostPosted: Sun Apr 04, 2010 4:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Done for now. I have ordered some side-panels from www.synthwood.com (have waited for 2 months but hopefully they will show up anytime soon).
don't forget to adjust the voices, etc by using the steps mentioned in the service manual (find it here: http://www.hinzen.de/midi/juno-106/manual/index.html)
In the mean-time i try to figure out how to fix the white-noice problem. Do anyone have a clue what would be the best starting point in trying to narrow down where the problem actually is? I also still have a slight "thunder" still (or should i say static?) which i don't believe has anything to do with faulty voice-chips. Do you guys have any hints or tips to share?
Kind regards
Daniel
 Filesize:  144.12 KB
 Viewed:  201 Time(s)
Audio files: 305
G2 patch files: 99
PostPosted: Mon Apr 05, 2010 4:18 am    Post subject: Reply with quote  Mark this post and the followings unread
I've got nothing to add here except my compliments on a thorough job and documentation!
/Stefan
PostPosted: Tue Apr 06, 2010 3:22 am    Post subject: Reply with quote  Mark this post and the followings unread
I would definitely look at replacing as many electrolytic caps as possible, starting with the biggest ones in the PSU.
This synth would be at least 20years old, and all the electrolytics would be drying out by now. Dodgy caps means dirty power rails, and when the big ones in the PSU get dry you end up with power rails which simply fail to deliver smooth, responsive power. This leads to transients being compromised and an increased noise level all round.
I know someone who has an M1 which recently became chronically distorted. Replacing 20 or so electrolytics (including the biggest PSU ones) has not only fixed the immediate problem, but has given it a "clearer, more dynamic sound than it has had for years." (This guy plays it live quite regularly)
my05
PostPosted: Tue Apr 06, 2010 3:28 am    Post subject: Reply with quote  Mark this post and the followings unread
/Stefan
Thank you Stefan,
In comparison to all the DYI:ers and skilled people on here, i haven't really done anything special to write home about Wink
(Men tack ändå. Kul att någon kollar in tråden Smile).
regards
Daniel
my05
PostPosted: Tue Apr 06, 2010 3:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Uncle Krunkus,
That is indeed a good advice. I have replaced a bunch of capacitors on one of my old pc-mainboards (where the fluid leaked out at the top, causing the computer to re-boot sporadically) so it should be doable.
Hmmmm... time to open it up again and write down a shopping list for caps... Smile
Thanks
regards
Daniel
PostPosted: Tue Apr 06, 2010 4:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Remember that the most important part is the value (uF)
You can use caps which are over rated for voltage (ie, if the original is 25V you can use that voltage or higher, not lower)
Keep in mind that if you have to go for a replacement with a very much greater voltage rating, you need to check that it will still physically fit into the space provided.
Try to get the pitch of the leads the same, but this is not critical.
There are newer "Low ESR" caps which could even make the de-coupling better than it was originally.
I'm thinking of doing my D50 soon. It's of (almost) the same vintage.
Ashe37
PostPosted: Sat Apr 24, 2010 2:03 am    Post subject: Reply with quote  Mark this post and the followings unread
The noise on my Juno 106 doesn't work either. Have you checked the slider to see if it is changing values?
E-Mu e6400 Ultra -Ensoniq VFX & ESQm
Korg M3, EMX-1 , MS2000BR
Roland MKS-50, Juno 106 Alesis Micron
Waldorf Blofeld
my05
PostPosted: Sat Apr 24, 2010 11:21 am    Post subject: white-noice Reply with quote  Mark this post and the followings unread
Hi Ashe,
I have but unfortunately nothing is heard besides a very slight change of "something" noice-like in the background. I have tried two different panel boards so i am pretty confident that the problem is elsewhere.
I did order two BA662's from Roland one week ago (still waiting for delivery). I assume (perhaps wrong?) that the 662 is used in this chain and can perhaps be the problem? They are not very expensive so i thought i might give it a shot Smile
At the same time, i plan to exchange capacitors (as uncle krunkus suggested). I got all needed caps for the PSU (exact spec, only slightly smaller nowadays) and a load of caps for much of the rest. Soldering time soon... Smile
I'll keep you posted on the white-noise issue.
Kind regards
Daniel
my05
PostPosted: Mon May 03, 2010 2:30 am    Post subject: Small update
Subject description: caps
Still waiting for the 662:s from Roland. In the meantime, i followed Uncle Krunkus advice and replaced some caps. I started with the big ones in the PSU and da-daaaaaa: No more hissing in the background Smile Thank you U.K.
Some images follows
(ps. and after 3 months of waiting, finally my wooden sides decided to show up. They were purchased from Synthwood)
 Filesize:  272.15 KB
 Viewed:  204 Time(s)
for that retro look :-)
 Filesize:  380.65 KB
 Viewed:  193 Time(s)
25 year old caps, big and dry vs. modern counterparts (same specs)
 Filesize:  296.73 KB
 Viewed:  193 Time(s)
PostPosted: Mon May 03, 2010 3:42 am    Post subject: Reply with quote  Mark this post and the followings unread
So how is the noise issue?
Something tells me it should be easier to trace it out than other possible faults on a Juno106. But I could be wrong. At least with the caps done, the noise source should stick out like the proverbial canine testes! Laughing
jc175
PostPosted: Sat Jun 05, 2010 8:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
Also looking for some information on fixing the noise generator - i own a Juno which is in perfect condition sans for the noise slider having absolutely no effect. If anyone's got any information it would be ridiculously helpful, cheers.
my05
PostPosted: Sat Jun 05, 2010 10:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
Unkle and JC,
Still waiting for the 662:s from Roland (they had to order them from Denmark and it has taken more time than planned). I called the service center last week and they said they would ship on Friday (2 days ago). We'll see. I went back to the electronics store (ELFA in the european countries) and got me some more caps (might as well do as much as i can muster while i am opening it up again to replace the 662:s). I'll let you know if this solves the noice-issues. Stay tuned.
Kind regards
Daniel
my05
PostPosted: Sun Aug 08, 2010 2:00 pm    Post subject: update - white noise Reply with quote  Mark this post and the followings unread
Just wanted to drop by and update you guys Smile
Got the 662:s and replaced them. That did not have any effect at all on the noise generator issue (altough not very expensive, it took some time to replace these - fully functional - chips.
Voice #6 decided to "kill" itself (the tone from it goes on forever and never fades away in the background) so a new clone chip is ordered.
kind regards
Daniel
my05
PostPosted: Sun Sep 05, 2010 7:49 am    Post subject: Restoration - the sequel Reply with quote  Mark this post and the followings unread
Well, i'm still at it. I finally got my voice-chips from D'naab in Belgium (analoguerenaissance.com) to fix my faulty number 6 voice (it emmited a weak tone in the background when the #6 voice was released). Ordered one extra just in case since i believe the rest of the Roland chips will soon start to act up as well.
Anyway, i managed to source a replacement for the noise generator transistor from a swedish company called "Elfa". The name/brand of this particular transistor is "NTE289A" in case anyone is interested. Afaik, this particular transistor is getting hard to source since they do not fulfill environmental directives (but again, there will probably be others that will and that matches the original....).
Long story short, i replace the original "NZ" transistor and.... didn't work Sad
Everything works great now except for this ¤&#//"(# white noise part.
kind regards
Daniel
