  bingsatellites Mostly Ambient
mixer is turned down, but still hear the 2nd osc
Page 1 of 1 [5 Posts]
Astral
PostPosted: Tue Feb 14, 2012 7:23 pm    Post subject: mixer is turned down, but still hear the 2nd osc Reply with quote  Mark this post and the followings unread
Hi All,
I am a little confused about the mixer section.
I have all the items in the mixer turned all the way down. I was assuming that when I played the keyboard, I wouldn't hear anything because everything was turned down.
Problem is I did hear something and I couldn't figure out what source it was coming from, then i turned the second oscillator and the pitch changed.
That must be the source, but why am i hearing it if I have it turned all the way down in the mixer section?
Hope someone can shed the light on this. I also turned off all mods thinking maybe an lfo was turning it up but that wasn't the case either, I dont think.
marctims
PostPosted: Wed Feb 15, 2012 9:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Are all the pots, in (both) the pre-filter and post-filter mixer turned to zero?
sunny pedaal
Audio files: 12
PostPosted: Fri Feb 17, 2012 3:37 am    Post subject: Reply with quote  Mark this post and the followings unread
try another patch, especially the default patch and try again if it leaks.
also remove all midicabels while testing
Astral
PostPosted: Thu Mar 08, 2012 7:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cool, must of been that patch. Started with init and all is good. I need to get in the habit of always starting from scratch.
Thx!!
sunny pedaal
Audio files: 12
PostPosted: Fri Mar 09, 2012 3:16 am    Post subject:   Reply with quote  Mark this post and the followings unread
fine
Niio1
