Using an oscilloscope voor calibration.
Page 1 of 1 [3 Posts]
soundforger
PostPosted: Fri Apr 06, 2012 3:19 am    Post subject:  Using an oscilloscope voor calibration.
Subject description: Is this one good enough?
I am building Ray's Ultimate & Ulimate Expander.
A while back I bought this osccilloscope:
http://www.seeedstudio.com/depot/digital-storage-oscilloscope-with-panels-p-514.html?cPath=174
Is this sufficient for the calibrating job or do i need one with other / better specs?
If so, what should i be aware of?
jordroid
PostPosted: Fri Apr 06, 2012 7:20 am    Post subject: Reply with quote  Mark this post and the followings unread
It's probably fine for most of what you need it for, and certainly way better than nothing. I'm a fan of cheap old dual channel analog scopes with big screens, but that one will probably serve you well.
For calibrating VCO waveforms and such, high precision is not really needed. Tweak it until you have a nice looking triangle and nice looking sine, the sine is probably best calibrated by ear once it is in the ballpark anyways, if it sounds good, it's good!
For VCO tuning a guitar tuner and your ears are the easiest way, IMO.
regards,
jordan
soundforger
PostPosted: Wed Apr 18, 2012 8:53 am    Post subject: Reply with quote  Mark this post and the followings unread
Sorry for the delay, but thanks for your reply jordroid.
I already ran a few tests and it seems to suit my needs, though i think i'll build a case around it that gives it a little more physical weight.
I'ts so light that i sometimes unintentionally drag it around my workbench....
More later.
