 Forum index » Discussion » Introduce Yourself
presenting the many sounds of wxl
Page 1 of 1 [13 Posts]
wxl
PostPosted: Fri Apr 20, 2012 2:25 am    Post subject:  presenting the many sounds of wxl
Subject description: aka Brownian e/Motion(s), Brownian Motion, The ERNIE 4, dj x∃n
  • howdy, i'm Walter Lapchynski.
  • i'm from the sister city to the inspiration for Bart Simpson's home.
  • on IRC, i'm wxl.
  • as Brownian Motion, i make all sorts of racket from harsh noise to drone. often times my work is subversive, but rarely in an obvious way.
  • as a member of The ERNIE 4, i help to create a dense field of all sorts of noise and ambient.
  • occassionaly, as dj x∃n, i play Creative Commons electronica. it's been a while. a long time ago, i used the name to mix electronica, industrial, goth, and even classical. at the same time.
  • not surprisingly, i'm an geek and worse yet, an open source one.
  • i use Linux.
  • i have a wee netlabel called Brownian e/Motion(s) which has mostly put out Brownian Motion and The ERNIE 4.
  • there are two compilations that i have put out-- one revolving around contact microphones and one that has to do with open source software.
  • two more volumes of this open source compilation are planned-- one with 100% open source used and a similar one with open source hardware, too. please get in touch regarding contributions!
  • have a nice day.
Brownian Motion happens.
EdisonRex
Audio files: 168
PostPosted: Fri Apr 20, 2012 4:10 am    Post subject: Reply with quote  Mark this post and the followings unread
welcome...
Garret: It's so retro.
audiodef
Audio files: 27
PostPosted: Sat Apr 21, 2012 7:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Welcome, Walter!
Do you use Linux for audio production? I do.
Audiodef
Synthetronica
Gentoo Studio
wxl
PostPosted: Sun Apr 22, 2012 11:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
hey peeps. yep, i use Linux for my audio everything. listening, producing, mixing, broadcasting, databending, you name it Smile
audiodef
Audio files: 27
PostPosted: Mon Apr 23, 2012 6:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Nice! What distro do you use?
Audiodef
Synthetronica
Gentoo Studio
onewayness
PostPosted: Tue Apr 24, 2012 9:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Yaaaaaay, more Linux geeks in the house. Smile
Hi Walter.
adh
handmade music for machines | onewayness.com
wxl
PostPosted: Fri Apr 27, 2012 10:06 am    Post subject: Reply with quote  Mark this post and the followings unread
lubuntu over here but i also like me some arch.
audiodef
Audio files: 27
PostPosted: Sat Apr 28, 2012 9:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Arch is nice. I wish I had a spare machine to run it on and play with it.
Audiodef
Synthetronica
Gentoo Studio
wxl
PostPosted: Sat Apr 28, 2012 11:32 am    Post subject: Reply with quote  Mark this post and the followings unread
you don't need a spare machine to play with other distros; that's what virtual machines are for Smile
audiodef
Audio files: 27
PostPosted: Tue May 01, 2012 10:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Heh, that's true! I guess what I need is some spare time for it. If I could only snag a tardis along with a VM, I'd be set for life.
Audiodef
Synthetronica
Gentoo Studio
onewayness
PostPosted: Thu May 03, 2012 8:18 am    Post subject: Reply with quote  Mark this post and the followings unread
kxstudio for me, or crunchbang if I'm traveling light. Wink
adh
Acoustic Interloper
Audio files: 26
PostPosted: Fri May 04, 2012 9:03 am    Post subject: Reply with quote  Mark this post and the followings unread
One of my goals for planetarium visuals is to generate a Tardis Cool
"Time is a ruler across the knuckles of eternity."
Dale Parson
"Just say no."
Nancy Reagan
audiodef
Audio files: 27
PostPosted: Fri May 04, 2012 11:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Just have K-9 emit a tardis video from his nose.
Audiodef
Synthetronica
Gentoo Studio
AmbiphonicDSP
