My Nord Electro boots with an error message!
Page 1 of 1 [8 Posts]
egregor1
PostPosted: Thu Jan 10, 2008 8:47 pm    Post subject: My Nord Electro boots with an error message!
Subject description: When powered on, the little display gives a cryptic error message and the instrument won't play.
It was actually in the middle of a gig a couple nights ago that my Nord Electro spontaneously powered off. While the rest of the band played on, I toggled the power switch, and when the instrument rebooted, the two-digit display (which typically shows "EL" and then "2.0" when starting up) showed "EL", then "E.7", then "rd" which remained indefinitely.
Now back at home and licking my wounds, the instrument continues to show "EL","E.7","rd" when powered up and won't make a sound.
Has anyone else ever seen this or similar error message?
Do the experts think this is a software problem or could something dire be wrong with the electronics?
Many thanks for your help in advance, I'm crippled without the great sounds of my Nord.
-Evan
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Thu Jan 10, 2008 10:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
welcome egregor1
I don't have a list stating all error messages, but at first I advise you to upen up the red hood and check all the cables inside the Electro. To open up unscrew the wooden sides, the screws at the back and some of the large ones at the bottum of the instrument. It doesn't happen often to the Electro, but due to transport, special to gigs, cables tend to get unconnected. Check it all.
Wout
egregor1
PostPosted: Fri Jan 11, 2008 1:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the welcome, Wout!
Here's an update with a happy ending:
I opened up the board and checked all the cables. They were all still connected but the board was pretty dirty. I wiped down (with alcohol) most of the contacts and some other components and generally cleared the interior of the instrument of crap, which had accumulated all sorts of dust, hair, and other crud including (!) a guitar pick and a necklace pendant. I guess when you're gigging a lot you never know what's going to get down in there.
After reassembly, the board was still unresponsive in the same way I described. I hooked up the board to my computer via MIDI & USB and did a full reinstall of the OS and piano samples. Then, voila! it started up and played without a hitch! Hooray!
Conclusion: although I can't be 100% sure, I suspect that the pendant floating around (which I'm pretty sure got in there just before the gig, as someone else was loading my gear) brushed up against something and caused a short that wiped the board memory or something similar. Nothing physical in the Nord seems to be permanently damaged and after reloading the software, all systems are go!
-Evan
Audio files: 116
G2 patch files: 317
PostPosted: Fri Jan 11, 2008 1:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
egregor1 wrote:
a necklace pendant.
Ouch, that's a nasty bug, good you gave it a new home Very Happy
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Fri Jan 11, 2008 1:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
So E7 means 'jewelry inside' Smile
Wout
egregor1
PostPosted: Fri Jan 11, 2008 2:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, exactly. :}
I guess you can add that to your list of error codes!
Thanks for your responses.
-Evan
nordlove
PostPosted: Tue May 22, 2012 9:07 am    Post subject: Reply with quote  Mark this post and the followings unread
So I have an extra issue to add to this error code... just last week my nord electro 2 started booting up with this same error code, and when I connected it with usb and midi cables and downloaded all the necessary software etc... the 'electro tool' boots up with a message saying 'No Nord Electro Found, check USB connection'.
I've tried two usb cables, both of which are in working order...
Any ideas? Please help, I'm really getting frustrated now.
thanks!!!
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Sun May 27, 2012 8:05 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi and welcome
Better is to contact http://electro-music.com/forum/profile.php?mode=viewprofile&u=25670
Pablo is the service tech of the American distributor.
He knows best what to do and is member of this forum.
Wout
