<on air> Asheville electro-music festival live stream
 Forum index » DIY Hardware and Software » Musical Interfaces
Live audio to midi trigger - is there a program that does it
Page 1 of 1 [12 Posts]
nilsomat
PostPosted: Wed Feb 22, 2012 12:26 pm    Post subject: Live audio to midi trigger - is there a program that does it Reply with quote  Mark this post and the followings unread
Hi forum,
just fould this advertisement about a new controller which lets you play midi drums from any surface where you stick the transducer to.
I think this is really interesting.
http://pulsecontroller.com/welcome.html
I would instantly buy this but since it doesn't support windows and they won't ship to europe, i was thinking of a pure software solution to replace this. Simply place a cheap contact mic on the table or whatever and plug it into the audio input of your computer. Then you would need a software which you could calibrate to the microphone and which converts the trigger to a midi note on with the velocity of the amplitude with a decent speed. Now just connect with your favourite drummachine or sampler and there you go...
Is there perhaps a software solution which lets you do this already?
Thanks,
Nils
nilsomat
PostPosted: Wed Feb 22, 2012 1:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
I love google!
It seems, the program "eTrigger" does exactly what i was looking for. Sadly i couldn't configure any audio input device since no device showed up.
Any ideas?
PickNick
PostPosted: Thu Feb 23, 2012 4:30 am    Post subject: Reply with quote  Mark this post and the followings unread
if you are using windows than you should try PureData or MaxMsp.
PureData is free...MaxMsp is not.
http://puredata.info/
http://cycling74.com/
i more prefer PD because i use linux and under linux there is no Max:)
quite same logic. there are tons of objects like audio input ///adc~
and midiout or noteout...
you have to create connections/nodes between the objects...
http://www.youtube.com/watch?v=FkmMzqohsDo
Allow theex.nl
nilsomat
PostPosted: Thu Feb 23, 2012 4:52 am    Post subject: Reply with quote  Mark this post and the followings unread
Great info, thanks.
I actually thought about MaxMSP before but thought there might be something more "simple". I will definitely have a look into the other program.
Nils
PS: Do you think the project is doable latency-wise for real-time triggering?
PickNick
PostPosted: Thu Feb 23, 2012 5:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Bug squash simple?
 Filesize:  191.12 KB
 Viewed:  5674 Time(s)
Allow theex.nl
nilsomat
PostPosted: Thu Feb 23, 2012 10:08 am    Post subject: Reply with quote  Mark this post and the followings unread
Ok, i did a little searching. Here is what i found:
http://www.youtube.com/watch?v=ovcIdHRn3TU
http://www.youtube.com/watch?v=OTl3C26v29s
Seems i will have to download puredata then...
nilsomat
PostPosted: Thu Feb 23, 2012 1:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
I have actually found some patches for Pure Data which allow me to do the same as the Pulse Surface Controller. It will just be a matter of tweaking them to my needs. I will have to check if latency is all right. Anyone interested?
PickNick
PostPosted: Fri Feb 24, 2012 4:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Wink
Forum index » Instruments and Equipment » MAX/MSP - Pd
cheers!
p
Allow theex.nl
PickNick
PostPosted: Fri Feb 24, 2012 6:49 am    Post subject: Reply with quote  Mark this post and the followings unread
nice blog:
http://cmpercussion.blogspot.com/2008/08/theremin-to-midi-control-program-in-pd.html
Allow theex.nl
nilsomat
PostPosted: Fri Feb 24, 2012 12:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey the Theremin to midi thing was very cool!
This is a good start for a drum trigger thing:
http://obiwannabe.co.uk/html/music/bonker/bonker.html
Couldn' test it though. No microphone Embarassed
PickNick
PostPosted: Fri Feb 24, 2012 12:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
buy some cheap piezzo:
http://www.electronicdrums.com/pads/pads2.htm
http://home.earthlink.net/~erinys/contactmic.html
or you can try some old headphones...like mobile headset.
its easy to amplify the signal in PD.
Allow theex.nl
wmonk
PostPosted: Mon Feb 27, 2012 5:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Some great information on drum triggers is available on the Paia website.
http://www.paia.com/ProdArticles/drumsens.htm
Even includes a nice schematic to use with the DIY drum pads.
Weblog!
