Lorenzo
Joined: Nov 09, 2008 Posts: 338 Location: Trieste - Italyjstan
Posted: Fri Jul 27, 2012 4:18 am Post subject:
how to get 5v, from +-9v?? |
the circuit I'm trying to build need +-9v and 5v to work.
For +-9v I will use two 9v batteries, but for 5v... have I to use three 1.5v batteries? or could I use the two 9v batteries someway?
Is it possible?
I mean to use 5 batteries for a little PCB seems to be a waste!
Suggestion?
Thanks! _________________ Oh Yeah!
Yes!
Wow! |
bod
Posted: Fri Jul 27, 2012 4:55 am Post subject:
the easiest and simplest option imo would be to use a 5v voltage reg and a capacitor on the input and output and supply it from the +9v connection.
the draw on the +9v will be greater than the -9v but would be better all round.  |
corex
Posted: Fri Jul 27, 2012 9:40 am Post subject:
| Agreed -- take a look at the datasheet for LM7805. |
Lorenzo
Posted: Fri Jul 27, 2012 10:04 am Post subject:
| bod wrote: | | the easiest and simplest option imo would be to use a 5v voltage reg and a capacitor on the input and output and supply it from the +9v connection. |
do you mean something like this? :
googling I found this topic, that seems to be written by me:
Question:Hello I am quiet nooby at the whole art of circuitry [...] can someone please show me how to build a circuit where I connect a
9V battery to the breadboard and by using my voltage regulator I change it to 5V
Please help me
Answer:You can simply use a voltage divider shown below:
Now, you want a 5V output so we'll have that for Vout and Vin is 9V. We'll just pick a random resistor value for R2 because of the ratio (but we'll have it in the KΩ range)...so for R1 you'll need a 19KΩ and for R2 you'll need a 20KΩ resistor. This will give you 4.6V which is very close.
so can I use 2 resistor only ?? or is better to build 9V to 5V voltage regulator using LM7805? I mean actually I haven't LM7805 at home!
Thank you very much for your kindly replies  _________________ Oh Yeah!
Yes!
Wow! |
richardc64
Audio files: 25
Posted: Fri Jul 27, 2012 12:01 pm Post subject:
| Lorenzo wrote: | So can I use 2 resistor only ?? or is better to build 9V to 5V voltage regulator using LM7805? I mean actually I haven't LM7805 at home!  |
It depends on what the 5V will be powering.
That formula doesn't take into account how much current will be needed @ 5V. If it isn't much -- which it can't be, since you plan to use 9V batteries -- then yeah, a voltage divider should be good enough. Keep the total resistance of R1/R2 low -- 1K or so -- so that what's powered by it "sees" a low impedance. Include a cap in parallel with R2 to smooth any fluctuations caused by varying currents.
This won't be ideal and you should eventually get a 7805. _________________ "It's quite OK to make music with tea spoons and rubber bands!" -- Blue Hell |
Lorenzo
Posted: Fri Jul 27, 2012 3:56 pm Post subject:
Thank you all very much! I will try a voltage divider on the breadboard... then, if the circuit works fine, I'll make things properly using 7805. _________________ Oh Yeah!
Yes!
Wow! |
JovianPyx
Joined: Nov 20, 2007 Posts: 1079 Location: West Red Spot, Jupiter
Audio files: 123
Posted: Sat Jul 28, 2012 12:58 pm Post subject:
The best way to get a steady stable 5 volts at varying currents is to use a regulator such as 7805 or 78L05. The datasheet for the 7805 shows a quiescent current curve that goes from about 5 mA to 6 mA. Quiescent current is the current the regulator draws just by being in the circuit.
9 volt batteries are not high current devices. They are composed of 6 small 1.5 volt cells and were designed for transistor radios years ago (often they were then called "transistor radio batteries"). If the current draw on the +5 rail is fairly significant, it will cause the 9v battery powering the 5v regulator to die faster than the other. In fact, most analog application circuits tend to exhibit a behavior of higher current on the + rail than on the - rail. That said, you might be wise to power the +5 regulator from it's own 9 volt battery.
Also - do not be fooled by the use of CMOS and think that it's going to be low power. CMOS circuits are low power only when they are used in a purely digital fashion, that is, where the outputs are always at one rail or the other. Some very popular CMOS circuits used for audio with parts like 4069, 4049, 4007 and others are used in a "linear amplifier" configuration. The device then operates in some ways like a poor opamp This causes the device to draw much more current than when used in a digital manner. They can draw enough current to get physically warm.
Bottom line: know how much current is needed at +5 as well as the current requirements for +9 and -9. Then you can design a proper system that will not fade out and die when you're trying to get something done with it. And remember that a +5 regulator needs a minimum of +7.5 volts at the regulator input to operate statisfactorily. If the 9 volt supply to the regulator sags below 7.5 volts, the system will not be reliable. _________________ FPGA Synth Stuff
FatMan Mods
dsPIC Synth Stuff I am formerly known as ScottG here Time flies like a banana. Fruit flies when you're having fun. BTW, Do these genes make my ass look fat?
Lorenzo
Posted: Sun Jul 29, 2012 1:54 am Post subject:
| JovianPyx wrote: | The best way to get a steady stable 5 volts at varying currents is to use a regulator such as 7805 or 78L05. [...]
the 9v battery powering the 5v regulator to die faster than the other. [...]
Also - [...] Bottom line: [...] |
ohh... Thank you very much for your exhaustive reply!! _________________ Oh Yeah!
Yes!
Wow! |
