need help for debugging my schematics & pcb
Page 1 of 1 [2 Posts]
jean bender
PostPosted: Wed Jul 25, 2012 5:49 pm    Post subject: need help for debugging my schematics & pcb
Subject description: first time i do it and i don't see what doesn't work...
Hi all.
I've developped a little noise box on breadboard, made a schematic, and i've already built three units from my schematic...
it's a pretty simple noise boxe, and i thought it would be easy to make a pcb from it.
I did it, but... it doesn't work, nothing.
i give you here my eagle files, if someone can check it and give me a trick... i would be very happy to understand what happens... or if you preffer, why nothing happens once my pcb drilled and populated.
thanks per advance...
 Filesize:  24.67 KB
 Viewed:  1259 Time(s)
mememtumBox.sch
 Filename:  mememtumBox.sch
 Filesize:  136.2 KB
 Downloaded:  206 Time(s)
http://h.a.k.free.fr/
www.electroncanon.org
jean bender
PostPosted: Thu Jul 26, 2012 2:06 am    Post subject: Reply with quote  Mark this post and the followings unread
ok, forgot my request, i've found the problem : two of the three 4011 osc are miswired, their condensators should be before the pot, and not after.
this works now.
not always easy to debug something when you still discover everything !!
