Thank you Mr.Yves
Page 1 of 1 [10 Posts]
axl
PostPosted: Sun Oct 28, 2012 7:56 am    Post subject: Thank you Mr.Yves
Subject description: Your website inspiring me to built my first modular
thanks for you job and your passion Yves!
I've start one month ago, I've built a couple of Monimoog Vcf and a wave folder.
Here some picture made with a cheap phone ahahahahah.
Just one question if some one can help me, is it normal the VCF is so noisy???
I have a kind of ground noise around 100hz @ -27Dbfs it's a bit huge right????
I've don't matched the 47n capcan be this the problem??????
 Filesize:  279.88 KB
 Viewed:  36 Time(s)
 Filesize:  397.23 KB
 Viewed:  39 Time(s)
 Filesize:  357.87 KB
 Viewed:  39 Time(s)
 Filesize:  172.27 KB
 Viewed:  38 Time(s)
axl
PostPosted: Sun Oct 28, 2012 1:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
I think is something to do with resonance if i disconnect the pot, or move the trim the noise drop down.
if i calibrate the trim the noise go up.....
Sebo
PostPosted: Mon Oct 29, 2012 10:40 am    Post subject: Reply with quote  Mark this post and the followings unread
100Hz is probably hum from the PSU, the hum is worst when you turn up the resonance as the circuit consumes more current. Try a better PSU with more current capacity, or try to connect only the VCF to check if the problem goes away.
Sebo
My Music:
www.cosaquitosenglobo.com.ar
axl
PostPosted: Mon Oct 29, 2012 4:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi sebo,
thanks for the reply!
I've try to connect only the vcf but the problem persist,
If i connect the wavefolder i don't have this problem so i don't think is that but maybe Im'wrong..........
I'm using the 15v psu from curetronic.
axl
PostPosted: Tue Oct 30, 2012 12:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
PROBLEM SOLVEEEEEEEE!!!!
was one of the 2 capacitor on the power soket
WEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEE Razz
ungleichklang
PostPosted: Tue Oct 30, 2012 12:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
congrats ... just wanted to answer ..
I have curetronic powersupplies (so meanwell PSUG) too and there is no humming
btw. nice builds and welcome to the modular madness Wink
My new blogspot: http://ungleichklang.blogspot.com
My Youtube-Channel: http://www.youtube.com/user/ungleichklang
My old google-site: https://sites.google.com/site/ungleichklang/home/s-diy
Linux Musician
axl
PostPosted: Tue Oct 30, 2012 6:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks mate!
Ye the curetronic psu is pretty cool is'nt???
Is the better i could find online.......
How many module can you run with it???
ungleichklang
PostPosted: Wed Oct 31, 2012 12:45 am    Post subject: Reply with quote  Mark this post and the followings unread
axl wrote:
Thanks mate!
Do you have the older "open" one or the closed (caged) one ...??
You can't say how many modules exactly can be run with a PSU, it all depends on the Ampere it can deliver and the module takes ..
f.e. (easy explanation) :
there are VCF that take 5 mA and others that take 30 mA
the Yusynth Fixed Filterbank takes 70 mA
the one VCO takes 40 mA another takes up to 100mA
Klee and MPS need ~100 mA each
and so on,
it also makes a bit how much it takes on the -15V-Rail and howmuch on the +15V
normally its both the same, but some modules don't
so it all depends on the modules you build
my curetronic-PSU (which is a Meanwell PSAI 24W +15V -15V) will deliver 800mA on each Rail, so I can server about 10 to 15 modules with it ...
I have 4 of those PSAI, so in total about 3.200 mA for each Rail Smile
For the yusynth-modules I found this xls
http://ebookbrowse.com/currents-yusynth-xls-d102712152
Hope this helps a bit (and hope my explanaitions as non-professional are correct)
Linux Musician
axl
PostPosted: Wed Oct 31, 2012 6:34 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks for the reply, very clear!
I have the caged version, T-40C it can delivery 1,5A on +15rail and 0.5A on the -15 rail. (on the website is described is 2A for +15 and 1A for -15 but is not true).
How to know how many A i'm using??
Just take my digital amperometer and put the tip on the DC rail ????
thanks for the reply.
Just to know isn't better to use a big toroidal psu instead of 4 small one????
Just asking beacouse some time i've see inside some hi-end pro equipment (like API SSL and NEVE stuff) and alwis see big oversized toroidal psu
alex
ungleichklang
PostPosted: Fri Nov 02, 2012 12:59 am    Post subject: Reply with quote  Mark this post and the followings unread
I think that is the best way, else you only can assume how much it is and keep it in mind if any weird things happen after adding a new module ...
alex
I bought the PSAI cause it has same mA on both Rails, plus I might decide (already have decided) to build another cabinet (2nd and 3rd), then I can split them up or ....
I don't know => will see then Wink
Linux Musician
Niio1
